Post by gordian79 on Aug 15, 2011 15:04:10 GMT -6
Adjusted valves already they at .004
Post by gordian79 on Aug 15, 2011 14:42:26 GMT -6
Where would that safety switch be?
Post by gordian79 on Aug 15, 2011 14:24:59 GMT -6
I bought with no start condition for cheap so I can swap out engine into my running scoot.the running scoot has 3700 miles and it's making a knocking sound.yes scoot was dropped.I want to start this motor tonmake sure it's good. So unplug kill switch from cdi and attempt to start it?
Post by gordian79 on Aug 15, 2011 13:36:11 GMT -6
I've tried coil,cdi and stator from running scoot and it still doesn't start.I've also put the coil,cdi and stator from non running scoot onto running scoot and it fires right up.
Post by gordian79 on Aug 14, 2011 15:40:24 GMT -6
I tested the grounds and they are good.one thing I noticed is that the running scooter has 3 ground wires to the frame right below valve cover and the non running one had none.I added a ground from valve cover to frame.I'm assuming the other grounds the running scooter has are the starter and the battery grounds.One thing that's weird is that it cranks with kill switch in either position it even cranks with wires unplugged from switch.The spark I get is very weak I don't think it's enough to fire up.
Post by gordian79 on Aug 13, 2011 23:07:39 GMT -6
Spark plug is wet with fuel.I even opened up fuel drain valve leaked fuel so there's fuel in the bowl.
Post by gordian79 on Aug 13, 2011 22:18:08 GMT -6
I have a no start situation.I have spark but it doesn't seem strong and it sometimes goes away.I swapped out the following parts into a working scooter and the other scooter started.cdi,stator,coil,spark plug,starter solenoid.I have also done everything on the no spark diagnosis pdf file everything checked out fine.The only one that didn't check out was on page 6 where it says to "test kill switch itself".this scooter cranks with kill switch in either position.In fact it cranks with kill switch wires unplugged.it also cranks with side stand in the down position.
thanks
