Excaliber JCL 250
Post by excaliber on Aug 21, 2010 21:02:02 GMT -6
right on the money winchester
found a white plastic conn that had partly melted and one of the yellow wires had lost conn, right above the RR. same thing happened with the white conn from the stator wires a while back, recon they are not heat tolerable.
cut out the conn and used a better quality one, works great
will soon replace all my amber/red lights with led.
Excaliber JCL 250
Post by excaliber on Aug 21, 2010 15:10:08 GMT -6
I read up on this www.scooterdoc.proboards.com/index.cgi?board=electrical&action=display&thread=1498headlights and tail/running lights BUT am getting power ... the little switch on the front of the left handlebar just in front of the bright/dim button is. if i press that the lights work fine?? what is that button for anyway? an emergency light switch? as apparently it by passed the main light route. i found only 2 fuses one to the radio and one a blue 15 amp not sure what it goes to.
Excaliber JCL 250
facebook
by: excaliber - Aug 20, 2010 14:11:46 GMT -6
Post by excaliber on Aug 20, 2010 14:11:46 GMT -6
Use FB its a great app, and will soon be one of the best tools on the web, i use it to keep up with family, coworkers, fellow gamers. and now most media outlets uses it, and sports..
Its the best connection app out there.
Excaliber JCL 250
Post by excaliber on Aug 8, 2010 15:22:18 GMT -6
another option did some googling and found some folks useing washers to add lower ratios?
Excaliber JCL 250
Post by excaliber on Aug 8, 2010 15:11:59 GMT -6
Zug is absolutely right. Find out what you are running now (Take one to your local post office if you don't have a scale). Whatever you have stock, drop one gram for a slider to get a better takeoff but keep the same top end. A slider weight will act like (About) 1 gram less than the same weight roller but keeping the same top speed. Expect each gram you drop from there to be a little less than 1mph off your top speed in most cases in return for better low end. ok, so now wheres the store?
Excaliber JCL 250
Post by excaliber on Aug 8, 2010 15:09:46 GMT -6
ya what bud said...
need a list of what is needed for high ratio or a low ratio? what to you ask for when ordering?
err i need a low geared variator........ store clerk say... hmm ok we have 200 of then all different which one you want?
Excaliber JCL 250
Post by excaliber on Aug 8, 2010 13:59:25 GMT -6
ok this is all new to me, after reading and watching the tubes i have a Q
what are the options on what you want? mine is stock, and with the wife and I we are hauling close to 400 pounds
i do not understand the slider/rollers/grams/weights options is there a scale depicting what you need for a set ratio?
Excaliber JCL 250
Post by excaliber on Aug 8, 2010 13:44:43 GMT -6
installing a variator
Excaliber JCL 250
facebook
by: excaliber - Aug 7, 2010 16:59:34 GMT -6
Post by excaliber on Aug 7, 2010 16:59:34 GMT -6
ya for me FB has become a necessary tool and being a gamer it has its perks.
Excaliber JCL 250
facebook
by: excaliber - Aug 4, 2010 20:31:43 GMT -6
Post by excaliber on Aug 4, 2010 20:31:43 GMT -6
for some reason it glitched....
o results found for Smorkle Bzzt. Check your spelling or try another term.
~~ come on down hwy 23 the pig trail
Excaliber JCL 250
facebook
by: excaliber - Aug 4, 2010 14:08:57 GMT -6
Post by excaliber on Aug 4, 2010 14:08:57 GMT -6
Just created a new FB group called "scooters" www.facebook.com/group.php?gid=148081775208551#!/group.php?gid=148081775208551 If you use FB add me i am 54 and have been a geek/webjunkie since 1993 and am also a gamer. ohh facebook i did not use it for 2-3 years after getting it, but now i use it to keep up with my kids and coworkers and fellow gamers.. add me excaliber@tcworks.net / dennis charles
