Post by backyardmech on Feb 10, 2013 13:08:41 GMT -6
yeah, I have extra pods laying around from my chopper builds, just need to gather up the rest. I like your stabalizer bracket. I can see where it would help alot on the intake manifold side as well...a big deal with this buggy since it bounces all over the place.
I live out in the boonies in the Ozarks, so threw the pantyhose on it and went for about a 1-2 mile run through fields and dirt roads, and this thing is a blast...makes ya feel like a kid again...
probably will play with the weights now that it runs right as I need a bit more torque for climbing the hills around here...
Post by backyardmech on Feb 10, 2013 12:06:04 GMT -6
PROBLEM SOLVED
Anytime I post for help on a forum I like to make my last post a detailed acct. of what I found as I so much appreciate the time that members like Alleyoop, Beachbum, etc. are willing to devote to total strangers. I recommend anyone recieving help do this so that other members will benefit from the search function for solutions. Thanks guys!!!
So anyway, as you know, the only visual problem I had found so far was a leaking/defective bowl gasket on the carb. So this morning I replaced the gasket with the used one from my old carb, carefully using a light coating of black gasket maker as that is what I had laying around. (I do not normally recommend sealers on a carb as you have to be able to take it apart and back together easily plus sealers can stop up passages etc., but the old gasket was flattened out and prolly would not seal, I did not have another one and was ready to get this show on the road...lol)
I then reinstalled the carb, fired up the buggy and took it for a spin not bothering to put the airbox back on and it ran like a bat outta hell all the way through the throttle.
So I'm thinking how the heck can a minor leak from a bowl gasket have cause this?
So I go ahead and button up the stock airbox on it and take it for another spin.
Right back to where I started..no additional speed/rpms, whatever past about 1/2 throttle!
So I take the side cover and filter off the airbox and try again...no improvement...
Alright then. I remove the complete airbox and tube to carb. She runs like a bat outta helll again!!!
She just simply wasn't getting enough air at the top end even with nothing but the stock airbox opened up and the airbox tube.
So I got to looking in the tube and noticed that where the tube curves then curves back again, even though there were no foreign restrictions, just the way it curved and the fact that it was old and a bit soft and ovaled out seemed to cause a weird flow and restriction.
That being said, I will be rigging up a straight pipe with pod so as not to trash out my carb. In the meantime, think I'll just throw a piece of pantyhose over the throat so my kid can play today....lol
Some may think I just solved a jetting issue at the main from the opposite direction by increasing air flow...but I don't think so because...
1) I am running a new stock replacement carb, and altho I don't know what the jet sizes are they are stock for the original airbox.
2) I've pulled the plug after every test run throughout this ordeal and its the best I've ever seen a plug look, right on the money.
3) Has always, since I did other initial repairs, started right up and idled smooth, and been responsive up to that 1/2 or so throttle mark.
So it was just starving for air at higher rpm.
So just another simple thing ou can try if you have this problem!
Thanks so much, I learned alot about these gy6's here....totally different from the old skool chops I build. AWESOME forum! I will enjoy popping back in.
Post by backyardmech on Feb 9, 2013 18:57:23 GMT -6
best I can tell they didn't do anything but buy it, ride it into the ground and when it wouldn't run anymore they threw it out behind the shed and let it go totally to hell....lol
yeah...I'll round up an impact wrench and confirm or eliminate that as the problem. I was watching the kidnme video on cvt's in the tech section and they mentioned flatspots in the weights would cause hesitation on the low end?
You know, another thing I've been thinking...since the carb, some of the hoses, etc, were all severely stopped up, the one thing that is not new in the fuel delivery is the vacuum petcock. Can a vacuum petcock be partially bad on the vacuum side or is it all or nothing. Just thinking since it fires right up, accelerates nice to 1/2 throttle or so, then just stays the same speed/rpm the rest of the way to full throttle (other than at that point it feels a little stuttery) maybe I'm hitting a starvation point for fuel.
Also, considering that, would you agree or disagree that the slight leak at the bowl gasket is a non issue? Even tho there was a leak there, when I pulled the carb the bowl had a lot of gas in it...
Post by backyardmech on Feb 9, 2013 17:45:34 GMT -6
...so I ran back down to mini storage and checked compression while the carb is still off...not gonna suck anymore air than that!
180 (I think that rates AWESOME in Alleyoops... lol)
Post by backyardmech on Feb 9, 2013 17:06:27 GMT -6
"When you tested the COMPRESSIOn did you hold the THROTTLE WIDE open when cranking."
ooops! no I just turned it over...guess I better do it again...
will throttle wide open make it higher or lower?
"Also you can verify if the 130 compression are your rings pour a teaspoon of oil down the plug whole and test the compression again if it goes up higher your about due for a ring job which is most likely the readings on the low side."
I thought you said anything over 120 was good?
Post by backyardmech on Feb 9, 2013 16:42:31 GMT -6
OK, 130, so good compression. Valve lash is good. Will have to wait to pull the variator as I don't have impact and the nut was too stubbern for my old skool rope in the cylinder trick as I didn't have room for much leverage (worked good on stator side).
I did pull the carb to find the leak which was getting a little worse and found that the bowl gasket had been pinched upon assy. Gasket from my old bowl was to wore to use it. Will have to see if I can come up with just a bowl gasket without having to buy the whole kit. I live out in the boonies and use ebay usually. Ideas?
I don't think it was leaking bad enough to starve for gas at top end, pretty small leak, but who knows? didn't seem to be a problem when up on the stands...
Did go ahead and pull and check the main while I had the bowl off just to be sure it was clear. It was.
I hope I find the weights are messed up to be honest because after that I have no ideas...but to me the weights still don't explain it running so good for the first hour or on the stands? Trying to wrap my head around it. I'll be near a harbor freight on tues. I think.
BTW, the plug looks beautiful, just that nice light brown speckle of a good burning spark.
Post by backyardmech on Feb 9, 2013 14:36:25 GMT -6
yeah, at this point I'm just going by ear as being a go kart it has no tach. Guess I need to get an impact wrench as, even tho I can see the belt ride all the way up the variator, I should at least still inspect it. I do have a compression tester and the ability to check valve lash...it just seems so strong on the bottom half of throttle tho. Do you know what psi range I should have if healthy?
BTW, when I first got this kart it looked good visually (not banged up, decent paint, fenders intact etc,) and I traded for it non running (didn't trade much haha), but the stator was shot, the battery was bad, the coil and wire was cracked up, the fuse was cut out, the 3 cdi boxes laying on the ground were questionable at best, the carb was corroded and thick with green gunk inside, slide frozen, many connections needed cleaning and the tires were bald and not all would hold air, so yes it was rode hard (out in the country thru creeks etc.) and apparently left outside when not in use...lmao. All of the above items mentioned have now been replaced and sorted thru. Oh, and the seat belts appear rusted in the closed position and I can't even free them up with pb blaster...haha.
Post by backyardmech on Feb 9, 2013 13:56:43 GMT -6
OK, I didn't see that last video before I left (so i might have to find an impact driver depending on your response to the following)...however my visual observations were that as I increased throttle the belt did ride up on the variator (the rear half of the variator moved out) and as I decreased throttle it rode back down (variator moved back in).
But the other strange observation I made again was that while the kart is up on the stands vs. down on the ground actually riding it, it sounds great. You can actually hear and feel the continued increase in rpms beyond half throttle on up to full throttle?
so would this still be related to the weights even tho visually I can see the belt moving up the variator and it sounds great on the stands with no load or whole different problem???
Post by backyardmech on Feb 9, 2013 12:28:39 GMT -6
Ok, going to head down to mini storage and do that now.....
Post by backyardmech on Feb 9, 2013 12:06:47 GMT -6
Hey alleyoop.....would it be the same to just put it up on stands and see if the slide is operating properly vs. pulling the diaphram?
...and why does it not seem to bog when on stands?
sorry...lots of questions, just trying to sort this out in my head after chasing so many other gremlins.
Post by backyardmech on Feb 9, 2013 12:03:34 GMT -6
CVT, Variator weights and belt
...is this inside the engine? I have a drive chain with a forward reverse looking transmission operated by a cable.
Sorry...this is all new to me. I build old school choppers. bought this for my kid and on a learning curve.
Gues I should check the rubber. Being a new carb I didn't want to void warranty by opening it up, but, hell I understand carbs and it was cheap enough so ....
One question I have is did they put different mains in different carbs and would it be unsual for my main to be to small? I mean were different mains in different applications of what looks like the same carb?
Post by backyardmech on Feb 9, 2013 11:56:55 GMT -6
Hey beachbum,thanks for the quick response. The leak is up higher (below that vacuum thing on the throttle side is where I saw vey light wet dirt accumulation?) and so minor I don't think it relates to the problem (I literally rubbed my finger on side of carb to find it...not puddling anywhere. I sprayed around intake and all is good.
Running a stock filter housing in good shape, no cracks etc. and same problem with or without it mounted.
Also ran kart with and without it mounted for that first hour when I first put the carb on and was testing it. At that point kart ran good either way.
Post by backyardmech on Feb 9, 2013 11:16:10 GMT -6
Hi, new to forum and appreciate any suggestions!
Bought a used/abused go kart 150cc gy6. After much headbanging, I got electrical issues solved and good spark. Carb was trashed, so ordered new carb from ebay seller, cleaned tank, new lines, filter etc. Read about vacuum petcock so checked to see if fuel was leaking into vac and it wasn't. Fuel flow seems adequete at idle. Starts right up and runs good at idle.
So here is where I stand. Install new carb and Kart ran pretty good (I have nothing to compare to, this is my first gy6) for about an hour. After that I went to ride it and it has no throttle response beyond about 1/2 throttle. Still runs pretty good and sounds strong until then but beyond 1/2 it falls on its face. (no speed increase and maybe sounds like it drops rpms?)
I did notice that if I put it up on stands with no load on it, it sounds strong thru out the throttle range?
Also noticed the new carb seems to have a very small leak, maybe at the bowl but haven't taken it off yet to check anything as it voids the warranty in case I need to return it. But just don't want to play parts swap, shipping back and forth if the problem I am having is a known problem. Of course, I don't know jet sizing in it but was advertised as a direct bolt and go replacement.
I did check and adjust my fuel air mixture as it was shipped at 4 turns out and sounds better at 3 turns out at idle, but this shouldn't effect top end anyway...
Just wanted to start with as much info on my end as possible..thanks in advance for any help...
