Post by gnargnarnate on Apr 8, 2013 17:22:57 GMT -6
i found a 15A fuse (blue), changed it out and it started right up!!!! Thanks for all the help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post by gnargnarnate on Apr 8, 2013 14:29:01 GMT -6
Mine looks identical to yours, however where your fuse box is on yours, mine just has an empty square where nothing is but is in the shape of the box. If that makes sense
Post by gnargnarnate on Apr 8, 2013 14:07:52 GMT -6
Alleyoop yes the 20A fuse is on the SOLENOID, the fuse was bad so i replaced it. Where is the box of fuses? I cannot seem to locate it.
Post by gnargnarnate on Apr 7, 2013 13:25:16 GMT -6
Hey i have a 250cc Roketa scooter that will no longer turn on. I have checked the battery, with a tester, and its still registering 12V. I located one fuse, close to rear wheel with cylindrical metal piece that goes into a rubber harness, and replaced the fuse which is a 20A (yellow). When i turn the ignition key to the "ON" position nothing happens, the lights do not turn on/the gas gauge does not raise to show amount of gas/the speedometer doesn't light up/and when i try starting the scooter it doesn't make any sound at all. I've looked for other fuses thinking that is the problem but cannot locate any. I have tried looking up electrical diagrams online but cant seem to find one that will explain anything, only pictures and prices. Any ideas at all what the problem could be? Thank you for reading
