Post by manxfella on Apr 24, 2013 13:48:42 GMT -6
Thank you for the reply Alleyoop, I have not altered anything as it was running then just started to die and has not run since. All I have changed is electronic. So should I now take the flywheel off and have a look at the key? Cheers again for your help, Baz......................
Post by manxfella on Apr 23, 2013 14:17:28 GMT -6
Pic 2 Attachments:
Post by manxfella on Apr 23, 2013 14:15:47 GMT -6
Hello all, Cheers for the reply Alleyoop. I hope these pics are some help. Thanks again for your time, Baz............................. Attachments:
Post by manxfella on Apr 21, 2013 13:01:30 GMT -6
Hello, Does anyone know if the timing can move on these engines and if it can how do I alter it? Cheers for any answers. Baz............................
Post by manxfella on Apr 15, 2013 13:23:16 GMT -6
Hello all,
Gatekeeper I have tried what you said and with fuel put in via vacuum inlet it still does not try to fire and compression seems good and there is a strong spark at the plug and there is fuel getting through the carburetor so you mentioned timing as a possibility if so how do I check this without the engine running as I would normally use a timing light with the engine running.
Thank you again for all the help being given,
Cheers,
Baz....................................
Post by manxfella on Apr 14, 2013 12:48:32 GMT -6
Hi kz1000st, I have tried a new plug but still will not start.
Cheers,
Post by manxfella on Apr 14, 2013 4:56:49 GMT -6
Thank you for your reply Gatekeeper, I shall try what you say and let you know. Cheers.
Post by manxfella on Apr 13, 2013 14:18:11 GMT -6
Hi all, I have a 2008 peugeot sum up scooter with a gy6 125cc engine, which was running then just died. I thought fuel but the plug does get wet and there is a good spark I have checked the valves gaps and they are fine but still it will not try to fire up, so replaced the cdi also the auto choke but still nothing and the compression seems good. I have now run out of ideas so If anyone can give me some info as what might be wrong?. The problem here in the Isle of man is that we do not have any shops that deal with Chinese engines Cheers for any help given, Baz........................
