Post by played1 on Dec 4, 2013 16:53:55 GMT -6
??? I need knowledge. I hope you can help. Here's the run down of what I have: 1.1p57qmj motor (stock internals) 2. 32mm CVK Carb 130 jet with performance manifold 3. 12 gram variator rollers 4. No rev limit CDI 5. Gates main drive belt 6. NGK Iridium plug 7. Upgraded Pipe, straight through 8. Stock fuel pump 9. Uni foam filter 10.upgraded variator from MosterGY6.com 11. Eliminated the CARB stuff 12. I swapped the final drive gear to because I was tached out and only achieved 45mph. I had full travel on the belt.
So the problem is I can only achieve 7000 rpm at about 50mph. I'm 225lbs. It can spool out on the center stand. I'm thinking I need to change my variator rollers to something smaller. But at the same time I know not many put such a large carb on a non-bbk. Or could it be a jet problem? I've adjusted the the air fuel ratio and it seems good. Also, it's broken in and has had valve adjustments. WOT seems to bog but not lose speed and doesn't gain it either. Can't figure this crap out for the life of me. Any ideas?????????
