Post by housedadtrains on Mar 7, 2014 16:29:59 GMT -6
Hi guys. new here so sorry if in wrong section.my problem is ive a sym mio 50cc. it has had new cdi aftermarket reg/rec resistors coil plug. now the thing is it will start and run of the kickstart as long as the battery is disconected. if you connect the battery which charges of the bike ok, the scooter will die. also when you crank the scooter it wont start as you lose the spark..
When the scooter is running lights everything works. if you put a bulb across the battery wires it still runs but not with the battery connected. Also if you take a charge voltage reading when the scooter is running it is only 7.5v?
I was wondering if the stator was dying or the battery? When it is running if you put the lights etc on it goes to stall but dosent..
any help appreciated..So in a nutshell it will start and run via kickstart but wont if the battery is connected.
