Post by redwood0318 on Apr 4, 2014 23:33:22 GMT -6
is over fifteen volts normal?
Post by redwood0318 on Apr 4, 2014 10:24:17 GMT -6
Recently my scoot has had problems staying charge at random times. ive tested the battery and it holds almost 13 volts easy for two days. I saw something on you tube about your voltage while the engine is running should be 12-15 but never more than fifteen. If thats true then what problems could that cause? and What is the best way to fix it. i havent blown any bulbs. no fuses are blown. Is it the regulator rectifier? The engine is a 1p39qmb. Thanks for the help!
