Post by adamhoyer on May 12, 2014 16:43:58 GMT -6
1drv.ms/1qxi5Fx Well.... I managed to strip both bolts but got one off with the impact lol. How can I extract these now?
Post by Bashan on May 12, 2014 17:55:46 GMT -6
Are they the Allen bolts?
Post by adamhoyer on May 12, 2014 17:59:01 GMT -6
Yes now circle bolts got 2 out now and one is half broke inside the threads and has a extractor broke inside of it.....
Post by tvnacman on May 12, 2014 18:07:49 GMT -6
Did you use metric allen wrenches ?
Post by Bashan on May 12, 2014 18:14:58 GMT -6
Kind of a moot point John. I've been there, start with a small drill bit and drill through the center of the mess. Then go to a slightly bigger size. Keep working up and eventually the remnants inside the threads will fall apart. Be careful and stay off of the threads. But first, if you can get any hold on the bolt try heating on the rotor but stay away from the bolt. If you catch it before the heat gets to the bolt it may release. It's tricky. Rich
Post by adamhoyer on May 12, 2014 18:40:50 GMT -6
Just going to take it to a machine shop tomorrow, going to cost 45$ because I got the extractor stuck in the middle of it.
Post by jvino on May 12, 2014 19:23:40 GMT -6
Bashan is giving you good advice. But you are right sometimes it's nesary to have someone else fix stuff. That's a bummer If you have a torch I would at least give it a try you might get lucky and get bolt to come out.
Good luck.
Post by Deleted on May 12, 2014 19:27:05 GMT -6
Just going to take it to a machine shop tomorrow, going to cost 45$ because I got the extractor stuck in the middle of it. yup thats probably your only choice now. those extractors are so hard nothing will drill into em. see if the machine shop will rethread it if they ruin the ones that are there
Post by adamhoyer on May 12, 2014 19:29:33 GMT -6
Post by jct842 on May 12, 2014 19:34:21 GMT -6
There is just not much hope to be able to drill thru an extractor, I believe they are a lot harder than most drill bits. There are ways to get around that. One way is to grind out taking a larger area then plugging the bigger hole and drill/tap. (Machine tools and shop)
Post by jvino on May 12, 2014 19:57:53 GMT -6
Yup. Couldn't of said it better jct.
Post by adamhoyer on May 12, 2014 22:25:44 GMT -6
Okay got a guy to tig weld on the top of the bolt and jerk it back in forth left to right and it took like two hours lol.
Post by mxmatt on May 13, 2014 15:45:48 GMT -6
Post by Alleyoop on May 13, 2014 16:02:25 GMT -6
Okay got a guy to tig weld on the top of the bolt and jerk it back in forth left to right and it took like two hours lol. Great! got someone to get if off for you. Most of us do not have the right equipment to get things done so the best thing is to take it to someone who does have the equipment. Glad you got her done Alleyoop
Post by adamhoyer on May 13, 2014 17:25:40 GMT -6
Waiting on glide keys for my variator so the sliders don't clank around when I'm driving and the new disc rotor bolts from scappydogs.
