Post by knottidedown on Sept 4, 2014 13:26:13 GMT -6
Hi everyone. I want to lose the air box on my 150 Powermax and replace it with a. K&N type air filter. Please let me know what I need to do in order to do so, ie., plug hoses and rejet, etc. thanks
Post by rks on Sept 4, 2014 17:10:37 GMT -6
Radiator hose, three clamps, one zip tie, about 1.5" of pvc pipe to connect air filter to hose....
Post by knottidedown on Sept 4, 2014 18:32:47 GMT -6
Did you have to rejet or plug hoses?
Post by Bashan on Sept 4, 2014 19:21:11 GMT -6
You will have a crankcase breather that probably comes off of the valve cover and plugs into the airbox. Do NOT plug it. Tie it off higher than the valve cover and stick a lawn mower gas filter in it to keep dirt out. If you have a vapor recovery system you'll need to remove it like this:
Post by rks on Sept 5, 2014 3:32:01 GMT -6
Did you have to rejet or plug hoses? Yes, you will have to re jet....Most suggest a jet in the 110 size for just a breather upgrade, and about 115, if both intake and exhaust are modified....Not written in stone (mine runs excellent with a 115 and stock exhaust)....most of us don't get it right the first time...have to experiment with a few sizes to get it right
Post by knottidedown on Sept 6, 2014 4:35:21 GMT -6
Thank you very much
Post by knottidedown on Mar 21, 2015 21:10:12 GMT -6
Can anyone tell me what air filter they bought for a 150 that worked?
Post by Alleyoop on Mar 21, 2015 21:16:56 GMT -6
Here is my setup, 24mm carb with a K&N Air filter Alleyoop
Post by rks on Mar 22, 2015 7:51:13 GMT -6
K&N, item RC 2290 works fine for me, as shown above. This is something you will have to figure out on your own, depending on where/how you want to install it. The frame on my scooter, and most others, is in the way, not allowing a direct mount to the carb. A piece of 1.5" (ID) radiator hose provides a nice snug fit over the 42mm mouth of a standard 24mm CVK carb. Then a piece of pvc, or something similar, with a 1.5" diameter. can be used to connect the hose to the filter.
Like I said, you'll have to take some measurements, and figure where you want it positioned.
The K&N goes for $37 or so, you can probably find a less costly alternative brand, of similar size, if you hunt around.
