Post by bdaniels914 on Jan 22, 2015 15:30:59 GMT -6
I have an ice bear pmz 50-10 49 cc.
i honestly know nothing about the mechanics of a scooter but I'm not paying someone to fix it if I can learn how to do it myself.
if anyone could give me simple instructions on how to fix this... From what I may know it could be a hole in the vacuum line or my carb needing cleaned.
it starts up just fine but dies within seconds. It hasn't been sitting either.
Post by Alleyoop on Jan 22, 2015 16:23:11 GMT -6
This is your scoot: If it starts and then dies it could just be the idle is to low or not enough fuel. Can you keep it running after it starts by giving twisting the throttle?
Post by Bashan on Jan 22, 2015 21:44:56 GMT -6
Adjust your valves too, that could have somethi8ng to do with it.
Post by cyborg on Jan 22, 2015 21:52:07 GMT -6
Both suggestions here are a good start,, if it lites up then dies right away Alley is on the trail,,, the idle is probably set too low,,, if it dies out after it warms up Bashan is on it with the valves being to tight and as the metal grows because it gets hot the valves are not closing and you loose compression and it will die,,,
Post by bdaniels914 on Jan 23, 2015 10:43:26 GMT -6
It will run for a long time but when i twist my throttle, it dies
Post by Alleyoop on Jan 23, 2015 11:51:37 GMT -6
That is a different story that is why you have to EXPLAIN exactely what and when things happen. So when you twist the throttle you are opening the butterfly and allowing a crap load of air to come in and it BOGs and dies due to NOT ENOUGH FUEL. So follow this procedure to adjust your carb: Alleyoop scooterdoc.proboards.com/thread/1499/4ts-carb-tuning
