Post by scoot on Feb 3, 2015 20:49:58 GMT -6
Thanks kavman but as I told alleyyoop I have a camera but don't know how to down size them to send to you guys sorry.
Post by scoot on Feb 3, 2015 20:57:07 GMT -6
You know I don't know ,when I cleaned the carb I just turned it upside down and let the fuel drain out wasn't paying much attention where the fuel was coming from.I'll check it out.(dam got to take this carb off again)thanks.
Post by Bashan on Feb 3, 2015 20:58:56 GMT -6
E-mail me the pics and I will post them for you. rich_carman@hotmail.com
Post by scoot on Feb 3, 2015 21:16:33 GMT -6
Post by Alleyoop on Feb 3, 2015 21:28:00 GMT -6
HERE IS HOW TO POST PICTURES USING THIS HOST. IT IS EASY AND FREE: 1. Click on this link: tinypic.com/index.php2. Click on Browse, that will link to your computer. 3. Find what you want to load. 3. Click on the name of the picture 4. Click on OPEN 5. Click on UPLOAD 6. Click on the LINK that starts with IMG. 7. RIGHT CLICK and CLICK on COPY 8. THEN Come here to your THREAD ON DOC. 9. RIGHT CLICK and CLICK ON PASTE. Alleyoop
Post by cyborg on Feb 3, 2015 21:41:37 GMT -6
There is something in the fuel line before the filter,,, it's either a small piece of plastic that lays flat for a while and then moves or someother flat debris that's acting like a flap valve
Post by scoot on Feb 4, 2015 21:28:08 GMT -6
got a few mins. free today and snapped some pics. sent them email as you asked hope this helps thanks again for all your help. scoot
Post by Bashan on Feb 4, 2015 23:10:31 GMT -6
Here are the e-mailed pics:
Post by Bashan on Feb 4, 2015 23:28:35 GMT -6
Post by Guitarman on Feb 5, 2015 0:25:51 GMT -6
I still say it's crud in the tank. Seen this same problem a few times now and it's been a dirty tank every time.
Post by jerryscript on Feb 5, 2015 1:27:39 GMT -6
The lines to the T connector with a cap on one end, that looks like one of the lines comes from the intake manifold, it should then attach to the fuel petcock. That vacuum line is what actuates the fuel petcock allowing fuel to flow through it. Is it hooked up?
Post by JoeyBee on Feb 5, 2015 1:50:00 GMT -6
The lines to the T connector with a cap on one end, that looks like one of the lines comes from the intake manifold, it should then attach to the fuel petcock. That vacuum line is what actuates the fuel petcock allowing fuel to flow through it. Is it hooked up? It appears from the pictures that the fuel petcock was bypassed for a straight gravity feed system. The T on the vacuum line was capped with only the carburetor attached to the vacuum line.
Post by JoeyBee on Feb 5, 2015 10:00:18 GMT -6
It may be just the angle of the pictures, but are you sure you have a good slope on your fuel line? Again, it may be the angle of the photos but a few spots in the fuel line appears to run slightly upwards. That could explain why you are not getting enough fuel to the carburetor, and how blowing into the tank vent to force the fuel down fixes it.
The picture of the rear of the scooter with both shocks is a good example. The line from the tank on the left-side of the frame appears to have the fuel line just below where the spring starts. However on the right side of the frame, the fuel line is above the beginning of the spring.
Post by Alleyoop on Feb 5, 2015 13:36:39 GMT -6
The only thing I would check is if when sitting on it the fuel hose is getting pinched. I labeled where I would check if putting pressure down the hose is getting pinched. To check if any part of the fuel line is getting pinched or moved just grab both sides of the frame and put your weight on it and see when that part of the frame goes down does it mess with the fuel hose. Alleyoop
Post by jct842 on Feb 5, 2015 13:44:40 GMT -6
1 thing for sure is that scooter hasn't been rode much.....so clean and shiney!
