1. A/F mixture.
I've read that I want to adjust it to where I have the highest idle. Does that sound good? Then after that I adjust the idle speed.
A. You are on it IN THE TECH SECTION 4T Carb tuning.
2. Charging system.
I have a multimeter, how do I make sure the charging system is working? I just want to check.
A. Connect it to the battery and at idle it should register 12.5-12.7 Rev it up and it should register 13+ volts.a
3. Back wheel/tire.
How the **** do you go about getting this on/off? I managed it today but it was a huge hassle, even completely deflated. The engine is in the way!
A. YOu did it no easy way it is a PITA.
4. Kill switch/Ignition switch.
Kill switch kills the engine. Simply turning the key to the off position does not. Problem?
A. The key off should kill your motor you have a problem, DO YOU KNOW IF YOU HAVE A DC OR AC CDI?
5. Any benefits to upgrading stator?
A. Only if you drive at night and want better lighting.
6. Testing for air leaks.
I've read you just spray places with carb cleaner and if the idle changes, there's a leak. Does this work?
A. Use water and or carb cleaner and spray individual areas IF the IDLE CHANGES you found a leak.
7. Fuel gauge doesn't work.
How to fix?
A. You have to take it out and see if the float is still good or disenagrated if good then check if the Contacts on the arm are making contact with the resister plate. IT could be loose and not touching or to tight and not moving. Or the contacts on the pivot arm are shot and you will need a new float sensor.
8. Rear break .
I'm having trouble bleeding it. Tips?
A. I take the cover off the and squeeze slowly and it bubbles up and do this until the handle gets harder. Other way is to take the cap off and take the fluid out and then bleed it from the brake side up to the brake handle.
9. Oil
Best oil for a 150cc scooter? Motorcycle oil?
A. Any good 10WX40 motor oil will do, just make sure you change it at least once every 1000 miles. I use 10wx40 Castrol Gtx.
10. Fuel/oil additives.
Any benefits?
A. I Use seafoam for every gallon of gas.
11. Overheating.
Summer is here and it's going to get hot. How do I tell if I'm overheating.
A. If you see the pipe getting blue and or the muffler it is overheating.
12. Tachometer
Any recommendations/how tos?
A.
www.trailtech.net/digital-gauges/tto?cat=11713. Rejetting
Any benefits?
A. If completely stock no, if a free flow filter and free flow muffler go up on the MAIN JET jet at 4-6 size from what is in there, leave the Pilot Jet as is.
14. CVT cover.
Does it need a gasket, really?
A. Not needed they usually rip when you first take the cover off.
15. Kickstarter.
I took it out, should I put it back in?
A. Only if you want a 2nd means of starting if your battery goes dead or gets weak.
16. Fuel Enricher
How to check if it's working properly?
A. Take it out and apply 12 volts to it. It should be retracted when taken out cold and applying 12volts to it in about 3 minutes the plunger should extend out about 1/4 of an inch.
All of these answers and how to's you can find in the tech section, I know I wrote most of the how to's.
Alleyoop
