Post by sunscoot on Jul 11, 2015 10:40:08 GMT -6
Are these ports to be left open or are there supposed to be hoses connected to them? Also where does the vent hose from the fuel tank get connected to? The hose from the fuel tank neck was just hanging. Scooter is a 2008 Roketa MC54-250B with Linhai engine.
Post by Alleyoop on Jul 11, 2015 10:47:44 GMT -6
Those two connectors are NOT USED they used to connect to the radiator the thinking was to flow some hot water to warm up the ENRICHER area for cold starts. The hose from the fuel tank is a VENT HOSE it has to vent so just zip tie it out of the way little higher than where it comes out from the top of the tank in case gas splashs out it will drain back into the tank.
Post by sunscoot on Jul 11, 2015 10:56:00 GMT -6
Thanks so much for the fast reply! Should I put a filter on the end of the vent hose to keep crap from getting the tank?
Post by Alleyoop on Jul 11, 2015 14:54:44 GMT -6
sure that would help so the spiders don't start spinning their web in the nice dark spot
