Post by bob123456789 on Dec 13, 2015 15:47:30 GMT -6
I acquired a used scooter. I was told the belt was broken. I ordered a belt and just finished replacing it. On the rear pulley, toward the back bottom of the case a spring was between the pulley and the case. I have pulled it out. Please see it in the attached picture. I will begin researching it right away but I could use some help in identifying it and determining the importance of it not being where it should be. I’d like to learn from the collective wisdom here. Some more background. The battery was also shot. I have ordered a new one. I couldn’t test the rear wheel drive until I got the battery. It should arrive in the next few days. Can I damage anything by testing the drive with the engine while something is missing that spring? The belt was not broken. I replaced it anyway since it had 5,200 miles on it and I was there with the new belt. I am a reasonably competent mechanic with many things (cars,…). However, I have not worked on a CVT before. Thanks for taking the time to share your thoughts.
Post by jct842 on Dec 13, 2015 16:00:58 GMT -6
Looks like a clutch spring to me.
Post by bob123456789 on Dec 14, 2015 4:52:59 GMT -6
This scooter is a JCL MP250A.
I have a Haynes scooter service manual that covers many scooter models at a high level. After reading it and some of the reference material here on Scooter Doc here is my preliminary line of thought. I'd appreciate it if you would let me know if I am headed in the right direction.
As Jct842 pointed out the spring I found is likely from the clutch. Between this and the fact that the scooter has 5,000 miles on it, and my desire to get this thing up and running as soon as possible at a reasonable cost I should probably go ahead and order a replacement clutch. I'm roughly guessing that the clutch is in the order of $100 and will take 5 days to get here. I'm not extremely confident about my ability to rebuild the clutch and while it would save a few dollars, it will likely take much longer with the scooter down.
I haven't taken one apart before, but I did watch a couple of the videos in the reference section posted by Bashan. I don't have a vice. I do have an electric impact wrench and a torque wrench. Is me being able to remove and swap the clutches a reasonable assumption?
Does anyone have any input that can point me to a reputable person on Ebay? I'd need someone who could perfectly match up my clutch the first time. It seems that this same scooter may be made under several names. I'm not confident in the other models that mine can be cross referenced to or alternatively named, Can anyone help with this?
The getting the correct part at a good price soon seems like it will take the longest. After I have ordered the replacement clutch I will remover the old one while I am waiting on the new one.
Any advice on this game plan would be greatly appreciate. If it sounds like I am off track please tell me a soon as possible before I order parts and get too far down this path.
Unless I hear otherwise from someone here today I will plant to order a new clutch today.
It would be nice to get this thing going since we only get three nice days a year to ride in Houston and I've already missed one.
Post by rks on Dec 14, 2015 5:00:13 GMT -6
Same here.....if so, you have one of the three clutch pads that is in contact with the drum at all times....not being pulled back in away from the drum at idle speed. This will cause more heat build up while stopped, or anytime engine is idling. Once underway, there isn't a problem with one missing spring, but you'll want to get things right soon.
Post by tvnacman on Dec 14, 2015 6:44:25 GMT -6
I think you can fix this without any parts. Open up the cvt remove the clutch the spring can be r/r. No need to remove the main nut on the clutch (the large one)
Post by Alleyoop on Dec 14, 2015 11:05:22 GMT -6
Yes that is a CLUTCH PAD SPRING it may be the reason it came off is the clutch pad broke off where it hooks up to in which case you need a new complete clutch. If the pad os not broken then you need to replace all the springs in the clutch so they are all pretty much equal in strength. Alleyoop
Post by bob123456789 on Dec 14, 2015 12:16:51 GMT -6
Thanks everyone!
A few questions/comments:
At 5,000 miles already appr what % of the typical clutches life have I used up already? 5% or 95%?
While it would be nice to not pull off the nut, I'm trying to picture how to replace the springs without removing the nut. How would that work? (the pictures help a lot alleyoop)
Any suggestions where to get parts in an low price way? Any Ebay experiences out there?
What other scooter models can I look for parts that can be used for this one (jcl MP250 A)?
Post by Alleyoop on Dec 14, 2015 12:47:26 GMT -6
You do need to remove the big nut to get at the springs. The springs are on the inside of the clutch. To get the right part WHICH MOTOR IS IN THERE. Alleyoop 244cc HELIX: 257CC LINHAI:
Post by bob123456789 on Dec 14, 2015 14:15:25 GMT -6
I can't say it is an exact match but I can tell that the block is horizontal like the second picture.
Post by Alleyoop on Dec 14, 2015 14:42:23 GMT -6
Post by bob123456789 on Dec 14, 2015 16:57:33 GMT -6
Thanks Alleyoop.
When I search your link to Ebay with Linhai 260cc there are several clutch assembly's that show up in the $65-70 range. the diameters are 80 , 140, 145, 132 and 135 mm. Is there any way to know which fits my JCL MP250A when it hasn't been taken off yet?
Post by bob123456789 on Dec 14, 2015 17:14:16 GMT -6
All of those ship from China. That would take too long for me.
Post by bob123456789 on Dec 14, 2015 17:15:47 GMT -6
To clarify, all of the ones I identified ship from China. There are other alternatives on the page.
Post by tvnacman on Dec 14, 2015 17:27:31 GMT -6
I can have it at your door in a week. Here is the catch I want measurements and pictures.
Post by bob123456789 on Dec 14, 2015 17:41:20 GMT -6
What is your price?
