East Tawas MI
Post by Tawas on Mar 14, 2016 9:44:43 GMT -6
I have my spark thread has stripped out can anyone tell me what thread it is as I want to get a kit to fix this being I have done this many times with other types with great results I just want to make sure I get the thread type correct 2012 VIP with BB kit 72cc but is same as stock 50cc thanks in advance ..
Post by trashtruck12172 on Mar 14, 2016 10:01:10 GMT -6
I think standard size would be 14mm x 1.5 thread pitch but I could be wrong.
Post by Alleyoop on Mar 14, 2016 11:21:50 GMT -6
East Tawas MI
Post by Tawas on Mar 14, 2016 11:42:44 GMT -6
Is the 14x1.5 correct he said he thinks it is can anyone tell me 100 percent that it is 14x1.5 thanks
Post by Alleyoop on Mar 14, 2016 12:24:18 GMT -6
All you have to do to get the right answer is GOOGLE for THE NUMBER ON THE PLUG like: WHAT SIZE IS C7HSA SPARK PLUG: You will find they are 10mmx1.0 pitch
East Tawas MI
Post by Tawas on Mar 14, 2016 12:28:04 GMT -6
thank you for helping me I really appreciate it ..means alot to me thanks again
East Tawas MI
Post by Tawas on Mar 14, 2016 15:04:18 GMT -6
After reading some of my older posts looks like my BB kit is the 80cc when I bought it it came with the kit but now I see on ebay they dont sell BB kit with the head on most since I stupidly stripped out my spark plug hole can I just put my stock head back on it looks the same as the one I have on now will this help me alot of hassle of ordering just the head since it just sitting in my parts shelf ..I did reading and sounds like I will be ok doing that just want to make sure before I start the repair ..thanks for helping as I have not work on mine in a while ..
Post by jct842 on Mar 14, 2016 19:38:06 GMT -6
What I would do is after finding the correct size, spend some time with a spark plug chart and pick out a similar plug the next size bigger threads. Then go borrow a spark plug tap that size to run in the bad hole.
I have done it before quite a few years ago and never had a problem. Those heads are almost as soft as lead solder, they tap easy and also strip out easy. When I put a plug in an aluminum engine I grip the ratchet right behind the head, and not the end of the handle and go just a fraction of a turn past snug. (those shorty ratchets are nice too if you don't put a lot of pressure on them) all it needs is enough tight to make a nice mark all the way around on the crush washer. If you flatten that washer out completely you are chancing a stripped thread. crushing it half way would be fine.
Post by Alleyoop on Mar 14, 2016 19:51:26 GMT -6
Yes you can use the old head, then since you have the stripped head off you can fix that one. Alleyoop
East Tawas MI
Post by Tawas on Mar 15, 2016 8:53:49 GMT -6
ok thank you for the help
