Post by bob123456789 on May 26, 2016 14:55:05 GMT -6
Thanks Cable guy.
I should have given a bit more of the needed info. I have a JCL MP250A which isn't a GY6.
Post by thecableguy on May 26, 2016 15:05:56 GMT -6
Yeah, I know, but it would surprise me if the brake master cylinder would be different... I'd give Jim at Rapid Repair a quick call and ask if they are the same. He sells/services most of these scoots...
Post by cyborg on May 26, 2016 18:07:29 GMT -6
I'd wager a guess and say they are the same as well unless it's a twin disc setup
Post by bob123456789 on May 26, 2016 18:52:50 GMT -6
Has anyone had any luck drilling the screw head off?
Post by cyborg on May 26, 2016 19:39:25 GMT -6
Yes I was going to mention that and if enough of the screw shaft is left you can sometimes catch it with vice grip needle nose pliers,,,if not you need to pilot drill it tap in an easy out and that will do the trick,,,but as I mentioned before to have that much loss where you can't see anything in the reservoir eye after you pushed the Pistons back there's a leak somewhere,,and my money bets on bad caliper seals,,,,,that's also why I said ,,,change the whole system,,,it's cheap insurance,,,I've wrecked a few bikes,,,it ain't fun or pretty to you or the bike,,,,for less than $150 you can have peace of mind knowing the brakes won't go away when the next a$$hole runs a red or does a left in front of you,,,,
Post by bob123456789 on May 27, 2016 10:24:23 GMT -6
I have never had much success with the easy outs. Has anyone been successful on a master cylinder of drilling off the top of the screw head. I could then remove the cover and get a vise grip on the screw shaft.
Post by cyborg on May 27, 2016 12:08:59 GMT -6
Not on a master cyl cover but on many a motorcycle/ car / machine plate drill head off needlenose vicegrips,,,with fairly good success
Post by bob123456789 on May 29, 2016 12:14:05 GMT -6
So good news is that the clutch is all put back on properly torqued with removable Loctite. The bad news is that the loose nut that holds the clutch on isn't what was making the noise in my earlier video (from post 20 of this thread). Have a listen to this video and see if you can identify the noise. Any ideas on how to solve it? Thanks. I appreciate everyone's help in getting this solved. View My Video
Post by cyborg on May 29, 2016 14:56:22 GMT -6
Video link takes you to tiny pictures video won't play
Post by bob123456789 on May 29, 2016 16:41:41 GMT -6
I wonder what I am doing wrong.
Can you see the video in post 20 of this thread?
Post by thecableguy on May 29, 2016 20:51:18 GMT -6
Played fine for me, however I'm at a loss for what would make that noise... Sounds like there's a marble rolling around in there. All the variator weights in place?
Post by bob123456789 on May 30, 2016 12:23:12 GMT -6
Cyborg do you reccognize that noise?
Post by cyborg on May 30, 2016 16:36:26 GMT -6
Can't get it to Play
Post by jct842 on May 30, 2016 17:13:42 GMT -6
Watched the video. Almost seems like the belt is slapping the housing in time with the noise!
Post by bob123456789 on May 30, 2016 18:13:04 GMT -6
I forgot to mention that it is a new belt.
