Post by jct842 on Jul 3, 2016 16:24:20 GMT -6
When a trike person see's this I think they are going to know what you have as well as the engine number. They are different. I would guess the engine number would be in same place as a regular scooter, lower left side near bottom of the engine case.
Post by crwford on Jul 3, 2016 23:49:32 GMT -6
First what size cc,what model,is there only 1 disk brake in middle or 1 on each wheel. What dia at spline and how many splines and how long is the shaft needed and what side is it. They have had many changes in rear end over the years. If it is a Ice Bear I'm talking about
Post by andrewc on Jul 4, 2016 11:07:24 GMT -6
It's the 300cc I can't figure out how 2 upload a picture
Post by crwford on Jul 4, 2016 12:17:38 GMT -6
What year is it and what side. In your case with a 300cc Rapid Jim should be able to fix you up. On my Zodiacs all have grease fitting which need grease regular If It were the ones chew up posted they look bone dry or someone cleaned them ?
