120/70-12
by: olivertwisted - Jul 25, 2016 22:40:10 GMT -6
Post by olivertwisted on Jul 25, 2016 22:40:10 GMT -6
Me too, richardv ! I appreciate the attention and thought to it When it first happened, I thought the same thing immediately, I thought "How can my cores be bad?! Both are brand new!" Then, I remembered the beads, as one shot out at me, lol! I pulled the cores and found one stuck in each.
Post by rks on Jul 26, 2016 14:11:58 GMT -6
One of the nice things about the beads is....they can be reused when it's time to change tires. Here's a link to Dynabeads info, near the bottom of page are filtered valve cores.
120/70-12
by: ucwt - Jul 29, 2016 7:06:49 GMT -6
Post by ucwt on Jul 29, 2016 7:06:49 GMT -6
Ok made my choice Any recommendations on a good place to purchase?
120/70-12
by: jct842 - Jul 29, 2016 12:13:48 GMT -6
Post by jct842 on Jul 29, 2016 12:13:48 GMT -6
Motorcycle super store
120/70-12
by: cyborg - Jul 29, 2016 12:16:22 GMT -6
via mobile
Post by cyborg on Jul 29, 2016 12:16:22 GMT -6
Chapparel or ebay
120/70-12
by: rks - Jul 29, 2016 15:32:02 GMT -6
Post by rks on Jul 29, 2016 15:32:02 GMT -6
I've gone to Motorcycle Superstore on numerous occasions for tires. Have also purchased them on Amazon, with Motorcycle Superstore being the one filling the order. A lot of things over $35 ship free on Amazon, at Mot Super it's $100.00 before that kicks in.
My wife says I'm cheap......I say no..... I'm frugal.
120/70-12
by: olivertwisted - Jul 29, 2016 16:06:06 GMT -6
Post by olivertwisted on Jul 29, 2016 16:06:06 GMT -6
FRUGAL +1 ! Why not get the best deal and quick shipping on a given item ? I like-a way you think rks
120/70-12
by: ucwt - Jul 30, 2016 10:27:47 GMT -6
Post by ucwt on Jul 30, 2016 10:27:47 GMT -6
Thanks for the input .
I stopped by a local scooter shop where they wanted 68 bucks For a no name tire, I can get two name brand off the net for 70
I stopped because I do try to spend my money local but got a sketchy vibe And overall state of the shop was meh.
120/70-12
by: jaxrhapsody - Aug 1, 2016 8:43:32 GMT -6
via mobile
Post by jaxrhapsody on Aug 1, 2016 8:43:32 GMT -6
I got a Shinko(think that's the brand) tire at the MoSuStore down the street from me, it was about 40$, Took the wheel off, and brought both to the Honda dealership, the other way, a little more than down the street, and they mounted it for 24$ and some change.
120/70-12
by: ucwt - Aug 1, 2016 10:27:52 GMT -6
Post by ucwt on Aug 1, 2016 10:27:52 GMT -6
I have spoons so I'll change mine over to save some coin but I will take them to be balanced.
120/70-12
by: ucwt - Aug 8, 2016 19:15:11 GMT -6
Post by ucwt on Aug 8, 2016 19:15:11 GMT -6
Ok so I haven't ordered my tires yet because the little hop isn't atrocious and I've Been having far too much fun riding......
During my most recent excursion I had pondered the buying of a different size.
What if I purchased a 80 instead of a 70 that should give me a difference at the top end and a little more ride height.
So has anyone gone up or down from stock? If so what are your findings?
120/70-12
by: cyborg - Aug 8, 2016 21:34:15 GMT -6
via mobile
Post by cyborg on Aug 8, 2016 21:34:15 GMT -6
I'm running stick size on my Stella but I've done that several times on motorcycles as a matter of fact I'm running a taller rear on my dualsport right now,,, a little altering of the final drive without changing sprockets
120/70-12
by: ucwt - Aug 9, 2016 4:46:37 GMT -6
Post by ucwt on Aug 9, 2016 4:46:37 GMT -6
A little more ride height is the ultimate goal seeing I don't intend to ease my turns any and drag the kickstand on turns, The few at the top end will just be a bonus.
Fitment without issues is my only concern seeing things are relatively tight already.
120/70-12
by: rks - Aug 9, 2016 9:24:15 GMT -6
Post by rks on Aug 9, 2016 9:24:15 GMT -6
My scooter came from factory with 120/70-12's....front and rear. I have recently changed both to 110/90-12 Michelin City Grips. If you do the math, you will find the 110/90 is 30mm taller than a 120/70....or in English.... 1.18" taller, and 3.7" further around it's circumference. I don't remember the exact measurement around the 120/70.....seems like it was 46 and a fraction inches, so the 110/90 increases the distance traveled per revolution by something like 7%.
You would need to make sure that you have enough front fender clearance for a tire that will ride a bit more than 1/2" closer to it. Rear one should be fine, as it is on my long case 157QMJ.
I feel the scooter looks better with a higher profile tire....and the load rating is much improved too.....64 compared to 51. This translates to 616 pound max load for the 110/90, and 429 pound max for the 120/70. (numbers from Michelin's chart)
120/70-12
by: ucwt - Aug 9, 2016 15:42:17 GMT -6
Post by ucwt on Aug 9, 2016 15:42:17 GMT -6
Right on!
Haven't done the math on sizes yet so that helps.
I will measure the remaining space from stock to front fender and see what I have to play with. Rear I don't have a problem taking it off because it is wonkey anyway.
Good looking out! Thanks!
