Post by msteele1690 on Mar 10, 2023 17:59:03 GMT -6
Looking for a Wiring diagram for the gauge cluster, when i acquired this bike, the prior owner changed the gauge cluster out and i have bought the same replacement that he had on it and i need to know what wires make the gas gauge work. on the scooter i have a blue-white, black (constant when key is on) light blue (Right turn indicator) dark blue (high beam indicator), Orange (left turn indicator), Green (ground).. on the gauge cluster i have: orange (left turn indicator) Light blue (right turn indicator), Dark blue (high beam indicator), Brown (backlight), (fuel gauge) Blue/White, Yellow, and red. when i test with a 9v battery using yellow as ground i get fast moving to past "F" using the blue/white to positive, and when i use red to positive i get a slow moving needle to "F", the prior plug was all kinds of messed up and basically fell apart when removing old cluster. just trying to get this back together, any help is good help and i thank you in advance. Mike.
