Post by cdog on Mar 15, 2023 7:07:17 GMT -6
Hi, I just replaced my blinker relay and got all my blinkers working...EXCEPT one (rear left). This blinker will not light. I've tried new bulbs, so it's not the bulbs. Can anyone give me insight how to fix this problem? Thank you!
Post by kz1000st on Nov 17, 2023 12:23:45 GMT -6
Pull out the bulb and check with a volt/ohmmeter and see if the socket has power. If not check the wiring into the socket and see if there is a good connection or power there. If so start back tracking the wire to make sure it isn't broken or a connector is pulled out of a circuit connector.
