Post by imagesinthewind on Apr 13, 2010 10:04:25 GMT -6
Peg: Type 4-Stroke, Single Cylinder, Liquid Cooled Bore x Stroke 58mm x 57.8mm Compression Ratio 10.3:1 Carburetion Keihin Displacement 152.7 cc Max. Torgue 9.0 / 6000 Horse Power 12 HP Ignition CDI Transmission Automatic CVT
Cadenza: Engine Type:Single cylinder, four-stroke Design:GY6 Displacement:150cc Bore x Stroke:1.90 in × 1.93 in (48.2 mm × 48.9 mm) Compression Ratio:9.2:1 Carburetor:Deni, joint venture with Keihin of Japan Max Power:9.6 hp (7.2kW) @ 7,200 rpm Max Torque:5.2 lbs·ft (7.0 Nm) @ 6,000 rpm Max Speed:64 mph
When Tom and I went out Saturday after the valve adjust I did some 'research'. From a dead stop, up a slight hill he dusted me. I was at WOT and he was pulling away. Cadenza engine has 1500 miles, Peg has 350. We both moved at the same time from the light.
The specs say Peg is 12hp, watercooled. Cadenza is 9.6, air cooled. Even without being broken in (1000 miles) I figure that I would be as fast if not just faster. 2.4 hp isn't small when working at these small numbers.
So, think my rollers are heavier? Why would the Peg be slower?
Thanks!
Post by Bashan on Apr 13, 2010 17:16:09 GMT -6
I've got a question, what do the bikes weigh? H2O cooled has more hardware, also pushing a water pump, could be sapping some of that HP. Rich
The Punisher!
Post by jake aka:ventoscoot on Apr 13, 2010 17:35:30 GMT -6
On thier own the Peg should, on paper, be faster. I do agree with Bashan weight may be an issue, I know my scoot is fast, but if I put a rider on it who weighs 160 insterad of my 240, it would scream. If I remember these body styles, the Peg is larger, no? Also rider height/wind resistance could be a factor. What is the curb weight (with no rider or gear) of each scoot.
Post by zugzug on Apr 13, 2010 17:48:31 GMT -6
Its probably because you put that big kite of a shield on it ;D -Zug
Post by imagesinthewind on Apr 13, 2010 19:48:34 GMT -6
Cadenza is 282# Tom is 185#
Peg is 286# and i'm 166# (I'm a Botticelli, but losing)
So the weight is about the same.
Post by Bashan on Apr 14, 2010 3:53:33 GMT -6
I'm going with the water cooled which is interesting, one can't look at just the HP and think it's faster or slower, there's other factors to consider. Does it seem slow to you? If so maybe there is something amiss in the fine tuning, who knows. Rich
Post by ♔Big Guy♔ on Apr 14, 2010 5:42:13 GMT -6
All things being equal, the Peg should be faster in theory, however, I can break out 2 Cadenzas from the crate and one might be faster than the other. These are all handmade, which means who knows who assembled the carb? What rollers were used? What belt was used... and so on. I have seen 3 different belts on the Cadenza, so all I can assume is they use whatever is in stock at the moment - same applies for other parts.
More important is the way factories report HP. Is it measured at the crank? Is it measured at the final drive? Are they fudging on their specs?? The latter is the most likely culprit.
And finally, your Cadenza is already run in, and when they are, they gain more power. I can also tell you that I have ridden at least 6 or 7 Pegs and 2 MC-12-150 Roketas and never felt that any of them were faster than a Cadenza. The power band on the Cadenza is smooth and responsive and seems to be tuned properly (parts wise) from the factory. We have never had to re-jet, change the weights or tune any Cadenza, other than fine tuning, like the AF mixture.
-Rich
Post by imagesinthewind on Apr 14, 2010 7:45:28 GMT -6
Thanks! Rich. I will let the engine break in more and maybe check the rollers first. I remember breaking open the Vie and finding 18s in it, changing them to 14/11s made the top end much faster and climbed hills better. If there are 18s in the Peg and 15s in the Cadenza that could make a difference. And this is the second engine in the Fly, the first, Tom says was very different than this one. He says it seemed broken in the moment it was installed. Faster by far then the first and smoother from the beginning. He is getting better, smoother power with each mile. And I have only given the Peg a mere 350 miles compared to Fly 1500. Peg seems fast when I'm riding alone. It seems slow when Tom is puling away from me. BUT I can hold it up and Tom tetters on it when riding. Finally had to measure each others inseam to prove my legs are longer than his. I'm going to shave the seat this weekend and install the Vapor Trail Tech to it so I can tell how fast/slow I'm going. Tom says the Fly hits 70 by China and is about 8% off.
Post by Bashan on Apr 15, 2010 6:11:04 GMT -6
Great info as usual Big Guy, Rich
Post by imagesinthewind on Apr 15, 2010 8:59:47 GMT -6
well, right now mine is much faster than the Cadenza, since the Cad isn't running.
Post by Deleted on Apr 23, 2010 10:18:43 GMT -6
Peggy Sue has 3800 miles on her, and routinely hits 65 mph for 10-15 minutes at a time.
Have you found any performance parts for the Peg yet?
Post by imagesinthewind on Apr 23, 2010 16:10:55 GMT -6
nope, but I haven't looked either.
