Post by prvrbs35 on Oct 11, 2010 18:16:20 GMT -6
Post by prvrbs35 on Oct 26, 2010 11:39:26 GMT -6
Well, it has been just over two weeks using a used spare clutch and bell housing without any problems. The pads on these OEM clutch plates do look to be different material at least in color. The one slipping is from a Lance while the other is from a no name Znen. Both have approximately the same amount of mileage logged. I do want to put my 1500 rpm contra spring back in and maybe change the clutch springs to 1500's as well. I like the response this set up gives.
Thanks for all the help regarding my scooter woes. I really get a lot of good information from this forum.
Post by Alleyoop on Oct 26, 2010 11:56:58 GMT -6
Stronger springs requires more RPMS to throw out the Pads, its just like putting in the Clutch in a car and getting the revs up and popping the Clutch:) Alleyoop
Post by monstergy6 on Oct 26, 2010 13:44:50 GMT -6
Sand the pads and bell with emery cloth or coarse sandpaper. Then apply this: It's boric acid. Apply it in the clutch bell and on the pads. If this doesn't work you may need a new clutch asembly.
Live to ride - ride to live!!
Post by kiwiscoot on Oct 27, 2010 14:41:20 GMT -6
I think my Citycom is starting to be infested with Roaches in the clutch department too, only problem is that we don't have roaches here so close to the Antarctic, so nobody stock the insecticide. Will have to get it from the internet and then it will be "take that you roaches!!" Strange how they seem to love the clutch, probably they like the heat and riding "Merry go rounds"!
Post by damorg5623 on Aug 16, 2012 16:39:52 GMT -6
I am also having a problem with my MC-54-250 Motor Scooter, Viberating/Shuddering, terribly when I first start off. I've noticed that it gets worse after the scooter warms up. I just got it last month, and I don't even have 300 miles on it yet. Goldenvale has been sort of helpful in trying to help me sove the problem, they did send me a NEW variator to try. That's what their mechanic thought that the problem might be. I am going to try and put the NEW variator on this weekend. Hopefully that will solve my shuddering problem. If not, then I guess I'll call Goldenvale back and ask them about a NEW clutch. assembly. It really makes you angry after months of saving up, and then paying all that money, for a BRAND NEW Motor Scooter, you finally get it... and It's got problems. Good Luck with yours!
