Post by rp on Sept 19, 2011 1:55:22 GMT -6
Has anyone ever taken the wires out of the CDI connector? I've tried using a small screwdriver, but can't get it to pop out.
Thanks
Post by Bashan on Sept 19, 2011 7:23:27 GMT -6
If you're talking about the two plugs into the CDI, they have a little tab that locks them in place. Use a small flat screwdriver to release them and they will come out of the CDI. If you're talking about the wires into the two plugs, they will also come out out by using a flat micro-screwdriver to push a retaining tab down. These things are sometimes hard to see but they're there. Rich
Post by rp on Oct 16, 2011 5:35:17 GMT -6
Finely got the trick down. Push up on the wire. then down with the screw driver( on the inside tab) and then pull out the wire. Slowly moving forward, Thanks
