Post by kountryguy on Oct 18, 2011 16:52:13 GMT -6
I have a 2008 Roketa MS-150-70 with about 2000 mi. I get a very little bit of oil dripping from the rear of the air filter housing. I took it apart today and wiped out the inside of the housing. There was not a lot, but should there be any? What might be the cause?
Retired Army War Veteran Living The Good Life
Post by trancebear on Oct 18, 2011 17:39:32 GMT -6
Too much pressure inside the engine.
Post by sprocket on Oct 18, 2011 18:06:03 GMT -6
Yes this is common... there may be a sponge that is suppose to soak up the oil.. so it may be plugged with old oil...wash with dish soap and dry well...
But if you have lots of oil then that might indicate you have overfilled the oil in the engine (it should be about 3/4 quart - 750 ml) or you have blow-by, oil passing by the rings...
Post by trancebear on Oct 18, 2011 18:41:20 GMT -6
Yea, what he said
Post by kountryguy on Oct 18, 2011 19:48:28 GMT -6
Where might the sponge be located?
Post by trancebear on Oct 18, 2011 20:16:50 GMT -6
should be in the air filter housing.
Post by kountryguy on Oct 19, 2011 8:19:51 GMT -6
Then I guess there is no sponge. Maybe I could add one!
Post by jct842 on Oct 19, 2011 10:47:18 GMT -6
my 2007 majesty has bad rings and I get a lot of oil coming out due to blow by. I bought it used and every oil change got me more oil coming out. It has about 90 lbs of compression now. I believe the rings were full of gunk and the oil I used more than likely washed it out. no more used scooters for me unless I figure an overhaul into the price and buy real cheap. john
Vespa Specialist
Post by Kaveman on Oct 19, 2011 12:34:30 GMT -6
If your a mechanical type of person , you could put a new cylinder and piston in yourself ! It woul save $$$ in the long run. Add that there is lots of help here on this forum and online if you get yourself into trouble. will
Post by Bashan on Oct 20, 2011 6:44:32 GMT -6
My wife has a 2008 Bashan Racer, it has this type air filter:
When you take the top off you can see the verticle vent tubes that extend through the bottom of the airbox, there's several:
I forget which one the crankcase breather originally hooked onto but it did dribble some oil out the bottom of the airbox. There was probably SUPPOSED to be a sponge in that compartment. Of course the idea is the airbox makes a slight negative pressure and draws oil vapor out of the crankcase. I now attach the breather to one of the compartments that doesn't have a drain and wipe it out once in a while. One of the tubes on the airbox is blind halfway through and if I hook the breather to that one there's no crankcase vent. Rich
