Post by mpdunhill73 on Jan 22, 2012 17:47:41 GMT -6
can I continue to use my original 125cc cylinder head with a 150cc cylinder barrel and piston?
Post by imnts2 on Jan 22, 2012 17:50:20 GMT -6
Probably. It might even be better. Should add just a little to the compression pressures. cheers
lefty2
Post by mpdunhill73 on Jan 22, 2012 17:59:24 GMT -6
Thanks for your reply lefty. I've still got the head to an old 180cc kit I had but I really wanted to keep the original head of the 125 with the 150 kit as I think the 180 head maybe just too much for the 150cc
Post by Deleted on Jan 23, 2012 9:42:10 GMT -6
yup that stock 125cc head will work just fine with a 150cc cylinder kit. and like lefty said adds a little compression pressure.
Post by mpdunhill73 on Jan 23, 2012 12:36:05 GMT -6
thanks scooterelements, it's always good to have another response on board
Post by Deleted on Jan 23, 2012 12:46:12 GMT -6
thanks scooterelements, it's always good to have another response on board No problem thats why i am hear to help others out with questions when i can. about a year ago i actually left my stock 125cc valve head and upgraded to a 58.5mm cylinder kit and it worked great!
Post by mpdunhill73 on Jan 23, 2012 13:11:48 GMT -6
i went for the 150cc set up cos i didn't want to machine the crankcase halves and also don't want that much power i just needed a little more for headwinds and hill climbs
Post by Deleted on Jan 23, 2012 13:18:39 GMT -6
i went for the 150cc set up cos i didn't want to machine the crankcase halves and also don't want that much power i just needed a little more for headwinds and hill climbs I understand that. When i first bought my 2004 scooter it was actually 125cc and not the 150cc like the paperwork said and of course it sucked on climbing hills and in Puerto Rico There is nothing but hills and mountains. so i upgraded and that helped alot. Remember tho on a 125cc scooter you can go up to 58.5mm without boring the crankcase! Let us know the improvements you have on your new setup
Post by mpdunhill73 on Jan 23, 2012 15:44:07 GMT -6
i will post back once the scoot is back up and running after the new piston goes in and ive ran it for a good few miles thanks for all your responses happy scooting
Post by sprocket on Jan 23, 2012 16:03:30 GMT -6
Be certain to hone the cylinder walls...
Post by mpdunhill73 on Jan 24, 2012 18:49:04 GMT -6
well here's a thing right? The camshaft is completely different to any previous gy6 i've worked on! It seems to be integrated into the rocker assembly. there are two bolts on the camshaft sprocket that are holding it onto the bearing assembly, i assume that i would have to remove those in order to release the cam chain so that i can pull the cylinder head off any further. i need to get my hands on a 7mm spanner to do this though as my range starts at an 8mm set upwards
Post by sprocket on Jan 24, 2012 19:07:40 GMT -6
If it a GY6 you should still have a cam chain tensioner... simply unbolt or release that to loosen the cam chain...
Post by mpdunhill73 on Jan 25, 2012 3:47:43 GMT -6
Absolutely distraught!! I got the new 150cc cylinder base and piston which stated that it was for engine models beginning with 152QMI only to find that the engine studs don't correspond with the new parts even though my engine is a 152QMI version Does anybody know where I can get the correct 150cc cylinder base for my engine? I'm in the UK if I can get postage here Note: Hey sprocket, I managed to get the chain off, I just wasn't pulling hard enough to release it as well as turning the engine while doing it :/
Post by sprocket on Jan 25, 2012 15:46:38 GMT -6
What sized wheels are on the scooter? If they are 16" then it could be a type B engine. The cylinder studs are spaced further apart
Post by imnts2 on Jan 25, 2012 15:52:43 GMT -6
Good point sprocket.
