Post by Deleted on Jun 6, 2012 12:54:24 GMT -6
Seen some people here post about piston shaving so i just wanted to post about my new build We just got the piston back today from the machine shop and they did a great job! Cost me $50.00 but well worth it! The last two pictures that has two pistons one if the shaved one and the other is the same one but unshaved. This was done for a 6mm stroker crankshaft.
Post by jct842 on Jun 6, 2012 13:13:52 GMT -6
looks good, nice work. I wonder how much metal is left on the piston head. /also will the weight difference effect the balance of engine? - 6mm should not be enough to change weight but you will see. That beats trying to get a spacer in there then find a cam chain that fits and more chances of oil leaks
Post by Deleted on Jun 6, 2012 13:39:43 GMT -6
looks good, nice work. I wonder how much metal is left on the piston head. /also will the weight difference effect the balance of engine? - 6mm should not be enough to change weight but you will see. That beats trying to get a spacer in there then find a cam chain that fits and more chances of oil leaks We still have to use a spacer otherwise it will hit. Finding a timing chain is the hard part. luckely there are other stores here in Puerto rico that carry a bunch.
Post by buford1488 on Jun 7, 2012 12:44:52 GMT -6
that's alot removed. be careful did the same and mine broke were it was cut. so i went and cut less and it's ok now. just saying by the pic it don't look like alot of metal left. just saying......buford.....
Post by Deleted on Jun 7, 2012 13:56:39 GMT -6
that's alot removed. be careful did the same and mine broke were it was cut. so i went and cut less and it's ok now. just saying by the pic it don't look like alot of metal left. just saying......buford..... There is actually still alot left that can be cut. I plan on getting a Wiesseco 62mm Forged Piston as an upgrade to this one but they are a little more expensive so i am holding out on that for now
Post by buford1488 on Jun 8, 2012 4:01:56 GMT -6
not to change your mind or anything check out honda piston's when i raced the honda was better then wiseco. just a thought for ya...thanks buford.
