Post by abispax on Jul 10, 2012 16:29:57 GMT -6
I just put the new rings on my scoot,adjusted the valves,and it apears to run good,but this morning,it took like 15 seconds to start,and lots of white smoke came out of the mufler,after 3 minutes no more smoke,scoot runs ine and after that it starts fine everytime,any advice on what to check? thanks for the help
Post by jct842 on Jul 10, 2012 23:02:57 GMT -6
don't be fixin what aint broke. Probably just some extra oil.
Post by Bashan on Jul 11, 2012 12:32:14 GMT -6
The rings will need seating too and will the smoke should stop when they do. Don't hammer it until the engine breaks in. Keep your oil checked. Rich
Post by abispax on Jul 11, 2012 18:26:22 GMT -6
The rings will need seating too and will the smoke should stop when they do. Don't hammer it until the engine breaks in. Keep your oil checked. Rich wise words,thanks
Post by sprocket on Jul 13, 2012 15:39:33 GMT -6
Did you gap the rings and stagger the gaps and hone the cylinder wall?
In a GY6 the rings only go in one way correctly...use nonnsynthetic oil for first 100 miles
Post by abispax on Jul 13, 2012 16:01:24 GMT -6
Did you gap the rings and stagger the gaps and hone the cylinder wall? In a GY6 the rings only go in one way correctly...use nonnsynthetic oil for first 100 miles i did all that,thanks.....
