Post by abispax on Aug 23, 2012 20:46:14 GMT -6
Well, last time i broke my engine due to a bad time setting i had, and im still saving money to rebuild my engine, however, i found a yunk yard that has lots of gy6 125cc engines, and i can get a full head rebuild for less then 45 dlls, im guessing that if the engine need rings, then it won be more then 50 bucks, but, the cuestion remains, does 125cc and 150cc had the same bore? (whatever that is) thanks for any help.
Post by sprocket on Aug 24, 2012 11:59:24 GMT -6
No the bores are different... but some parts are interchangeable. The 125 cc has a 52 mm bore and the 150 is a 57 mm bore
Post by abispax on Aug 24, 2012 19:18:09 GMT -6
they got full engines, ill see if i can get a good deal on it, about the parts, wich parts are usable from a 125cc that i could use?
Post by sprocket on Aug 25, 2012 13:05:51 GMT -6
The list is too long...
Post by abispax on Aug 25, 2012 17:43:02 GMT -6
of course i mean about the head parts.... ;D
Post by james03x on Sept 10, 2012 1:58:00 GMT -6
Well mostly main parts are compatible for 150cc but some parts can't change, you should contact a scooter workshop in your own town.
"His and hers"
Post by sledwrecker on Sept 12, 2012 0:29:54 GMT -6
There's a couple of guys on ebay selling complete 57mm stock top end kits for around $80 shipped. Everything is new, also comes with new oil pump and rollers. I can send you links if you PM me.
Post by tvnacman on Sept 13, 2012 3:54:43 GMT -6
There's a couple of guys on ebay selling complete 57mm stock top end kits for around $80 shipped. Everything is new, also comes with new oil pump and rollers. I can send you links if you PM me. I have the complete kits ready to ship . most external parts are interchangable the internals are different . remove your head and jug and measure the the hole . We can measure the 150cc jug to see if it will fit . Some parts are listed as 50-150cc or 125-150cc . It maybe hit or miss . I'm a small guy I don;t have to wait a week for some wharehouse guy to bring me a part to check for spec . John
Post by Deleted on Sept 13, 2012 12:09:27 GMT -6
My scooter when i bought it was a stock 150cc scooter "Suppose to be" after we opened it and measured it was only a 125cc scooter and the valve head the valves were smaller. What we ended up doing a long time ago is we just bough a stock cylinder kit and stock valve head and installed it. No problems. I ended up upgrading further tho
