Post by Gti on Sept 9, 2012 13:07:44 GMT -6
I am thinking of using this crank instead of going with the 4mm crank. Do i have to add shims or anything other than putting the engine together?
Post by justbuggin on Sept 9, 2012 15:17:52 GMT -6
not sure if you do need a spacer the best way to tellis to put the bottom end together piston on the rod and slide the cylinder down on it while holding the cylinder down rotate the crank to TDC and see if the piston comes out the top of the cylinder if it does then you will need a spacer the same thickest the piston comes out
Post by justbuggin on Sept 9, 2012 15:18:44 GMT -6
good luck with this build and if i can help just pm me
Post by Alleyoop on Sept 9, 2012 16:44:02 GMT -6
Ask JIM from RAPIDREPAIR he put in a 2.2 Stroker Crank on my motor. Alleyoop
Post by rapidjim on Sept 10, 2012 15:25:34 GMT -6
Haven't done a 4 mm stroker yet. I would almost bet it will have to be shimmed. I know a 2mm don't need shims.
Jim
Post by Deleted on Sept 13, 2012 12:07:21 GMT -6
I had someone post on another thread that installed a 2mm stroker and ended up bending the valves because he did not use a spacer. My scooter i have a 3mm Stroke crankshaft and i dont have a spacer but instead took the piston to the machine shop and had it shaved and the valve seats done. Here is a pic of my piston for my 6mm stroke crankshaft along side a stock regular piston
Post by justbuggin on Sept 13, 2012 21:29:26 GMT -6
does shaving the piston like that make it weaker and how do you figure how much to take off
Post by Deleted on Sept 15, 2012 10:00:59 GMT -6
does shaving the piston like that make it weaker and how do you figure how much to take off Most here shave the piston and they run great. Mine is shaved and it been like that for less than 2 years. The amount to take off depends on the stroker you are using. Most people either install the piston and see how much is coming out of the cylinder and mark it with a black marker. i can always ask the guys here at the machine shops what stroke crankshaft you are using and they know exactly how much to take off. its measured in Thousands of an inch.
