Post by curiousgeorge on Sept 20, 2012 4:52:24 GMT -6
So I need a new carb so that i will be able to adjust my air/fuel ratio properly because mine currently has an EPA seal on it. I see there are many different carbs and need some help choosing the right one. I have a Jonway agility 50cc, on the engine it also had something that said yy50qt-6 on it too, and i am not sure if that means anything. So do any of you think you could help me find the correct carb to go with my scoot so that way the auto choke connectors match and the carb size is a match, etc. Thanks for any help, Curious George.
Post by jct842 on Sept 20, 2012 7:39:14 GMT -6
Why not follow instructions posted on DOC to remove seal then you are assured you have the right carb. oop has posted a ton of information on doing that.
Post by gatekeeper on Sept 20, 2012 10:01:32 GMT -6
Post by cookees on Sept 20, 2012 20:30:33 GMT -6
We absolutely DO NOT drill them out every day....
Post by Alleyoop on Sept 20, 2012 21:18:52 GMT -6
Who said you guys drill them out every day? We ought to drill one of his teeth for saying that. Alleyoop
Post by curiousgeorge on Sept 20, 2012 21:42:33 GMT -6
how do i know if mine is a 139qmb? and is it easy to install a new carb?
Post by Alleyoop on Sept 20, 2012 21:53:36 GMT -6
Look under the CVT cover by the front the ENGINE number will be imprinted on the MOTOR on the side. And yes it is easy to install a carb. Alleyoop
Post by Cruiser on Sept 20, 2012 22:19:33 GMT -6
Here's the relative position with everything connected: Right above the centerstand.
