Post by Bashan on Apr 4, 2013 10:28:28 GMT -6
I have a couple questions.....I still don't know from this thread, do you have a lights off/parking lights/headlight on on the right handlebar? Second, when you turn on the key does the fuel gauge come up? Also, does the horn work and tail light come on with the key on?
Post by Bashan on Apr 4, 2013 16:25:17 GMT -6
If you have a lights switch I think this applies. The diagram is from the Kinroad site but I'm not sure it fits your bike exactly.- #1, turn on the switch and the black wire gets energized with 12v DC.
- #2, the black energizes the brown through the parking light setting on your lights switch.
- #3, the brown wire powers the dash and some other lights prior to starting, and afterwards also.
- #4, the brown also powers the tail light so it should come on with the key and the parking lights setting. Many bikes don't have an off setting, just parking lights and headlights.
- #5, once the bike starts the stator starts cranking out voltage which is regulated on the yellow wire to 12v AC.
- #6, push the lights switch to the headlight setting.
- #7, the blue/white wire is energized with 12v AC and the brown remains energized with 12v DC.
- #8, the blue/white then powers the dimmer switch which either powers the low setting through the white wire (#9) or the high setting through the blue wire (#10).
So what does this mean for us? The only commonality to your dashlights AND your headlights not coming on is the lights switch. That's where the dash lights and the headlights have a common connection. So as the guys said, you're going to have to get some plastic off and get to the switch. It may be bad or there may be a pigtail on it that's loose. Now, if you don't have a lights switch at all, I'm going to go kill myself.
Post by Alleyoop on Apr 4, 2013 17:09:01 GMT -6
Well you get to LIVE ANOTHER DAY(HAHA), he said he does have a Switch for HIGH and LOW but no Neutral its is one or the other, so they come on MAGICALLY. Alleyoop
Post by hiram357 on Apr 4, 2013 18:51:47 GMT -6
I have a couple questions.....I still don't know from this thread, do you have a lights off/parking lights/headlight on on the right handlebar? Second, when you turn on the key does the fuel gauge come up? Also, does the horn work and tail light come on with the key on? I have those on the left handlebars. When I turn my key on the fuel gauge comes up. The horn works and the tail light comes on once the key is on Thanks for the replies guys, I'll try to get back at it in the AM
Post by hiram357 on Apr 5, 2013 15:35:28 GMT -6
I just took off the front again and noticed some white wires going to the headlights with some browning on them. Like it's been burnt? Could this be the problem or should I look for something else? Here are some pictures: i.imgur.com/wNFaRyC.jpg& i.imgur.com/eruXwgA.jpg
