East Tawas MI
Post by Tawas on Jun 7, 2013 15:28:24 GMT -6
posted a message with no reply I will try again... 150cc baja go cart wont start ..have power to solenoid but does not click tried a new one and still no click voltage to battery is 12 volts but out to started is 0 tried two new solenoids and same on both what now
Post by Alleyoop on Jun 7, 2013 15:46:07 GMT -6
Jump the two terminals on the SOLENOID and if the battery is good it should spin your starter. When you TURN THE KEY ON and squeeze the brakes does your BRAKE LIGHTS COME ON? Also try the other brake and see if the brake lights come on Alleyoop
East Tawas MI
Post by Tawas on Jun 7, 2013 19:05:45 GMT -6
thanks traced ignition and had two plugs crossed ..why do these connector plugs fit into wrong plugs .thought they would make so no other plugs can plug in different areas but these plug connectors can enter change
Post by Alleyoop on Jun 7, 2013 19:25:52 GMT -6
So you fixed it?? problem SOLVEDEDEDEDEDED Alleyoop
East Tawas MI
Post by Tawas on Jun 14, 2013 17:01:35 GMT -6
well was fixed but doing same thing again all plugs are right ..its a go cart so brakes do need to be on this one ..i jump solenoid and runs tried another solenoid and still nothing ..no power to starter wont do anything please help
Post by Deleted on Jun 15, 2013 1:14:21 GMT -6
Check your fuse?
