Post by jjoshua20213 on Jun 20, 2013 9:14:00 GMT -6
So I start my bike, and oil and gas flow out of the valve vent tube. So i opened the oil to check things out and it floods my garage! It poured out the gushed out as if I broke a water pipe..... What now???
Post by jct842 on Jun 20, 2013 9:28:18 GMT -6
Float is stuck on carb. You will need to repair carb then drain and change oil.
Post by rob63 on Jun 20, 2013 10:59:00 GMT -6
Check the vacuum pipe which goes from the fuel tap to the inlet manifold. If the tap is faulty the fuel will flow down the vacuum pipe straight into the engine.
Post by jjoshua20213 on Jun 20, 2013 11:12:14 GMT -6
So i changed the oil, drove 6 miles then its gas in it again. Cant be the carb or fuel valve because it was running. I hadent had time to leak in it. Checked the gas valve and it works right. There is no way it got that much gas in it already if it were the float valve. It hasent even been an hour since the change???
Post by jjoshua20213 on Jun 20, 2013 11:47:59 GMT -6
Also had just changed to #40 idle jet. gives it better take off
Post by Deleted on Jun 20, 2013 13:17:28 GMT -6
Take the carb off the intake. Does gas leak out when it sits level?
Post by jjoshua20213 on Jun 20, 2013 15:25:21 GMT -6
No, but I put the old idle jet in and it fixed the issue. I guess it was running extreamly rich and was not burning all the gas and transfering it into the crank case.
Post by Alleyoop on Jun 20, 2013 15:38:45 GMT -6
Good move I was going to say a #40 jet even the 250s do not have one that big. The 150s will take a #35 stock if stick a BBK in it they MAY take a #38. Alleyoop
Post by jjoshua20213 on Jun 20, 2013 18:57:04 GMT -6
ya, scrappydog scooters sucks. Thats what the recommend. they also recommended a 95 main jet, and it was too rich to run. And I bought a flywheel and the pickup coil keeps getting hit my the magnet. Any idea how to fix that?
Post by chupik on Jun 28, 2013 12:47:15 GMT -6
Hi rob63 I was buy your aldy 125cc 3 days ago I wgote some questions
Post by Deleted on Jun 29, 2013 0:40:43 GMT -6
Like I said before, file the coil mounting bracket holes a little bigger. Then you can adjust it so it doesn't hit the flywheel.
Post by jjoshua20213 on Jun 29, 2013 1:05:58 GMT -6
thnx, DW
