Post by taildrag on Jun 22, 2013 14:17:15 GMT -6
I have a 2008 Roketa 54B. On a metal thingie inside the seat it says: Tires 130/60R13
Pressure..cold Front = 32 psi Rear = 41 psi
Is this correct? I would thimk when the tires got hot they would blow up. I have 3000 miles on this and have been useing arouund 27 psi front and back. Should I change??
Post by Alleyoop on Jun 22, 2013 14:23:58 GMT -6
Look on the tires themselves and it will tell you the max pressure then fill 10% less. Alleyoop
Post by LUKE on Jun 22, 2013 14:44:16 GMT -6
what? rear 41psi? wow!! mine is 32 just enough to roll me. man, research further, i think 41 is too much. its like your tire took 3 viagras!! so hard!LOL!!
Post by Alleyoop on Jun 22, 2013 14:51:46 GMT -6
It also depends on the AGE of the tires which any number of viagras will not help(HAHA). Alleyoop
Post by taildrag on Jun 22, 2013 15:00:38 GMT -6
OK...10% less then it says on the tire itself. Got it. Thanks.
Live To Ride / Ride To Live
Tire Pressure
by: richardthescooter2 - Jun 23, 2013 6:28:52 GMT -6
Post by richardthescooter2 on Jun 23, 2013 6:28:52 GMT -6
I have the same tire size, mine call for 33psi (both tires).
Post by taildrag on Jun 24, 2013 15:48:10 GMT -6
I looked on the front tire and it read 31 psi cold with full load. So with just one rider 27- 28 psi cold would be about right and that is what I have been using. I wonder why the metal tag under the seat read so much higher?
