Engine swap
by: jjoshua20213 - Jun 23, 2013 20:45:52 GMT -6
Post by jjoshua20213 on Jun 23, 2013 20:45:52 GMT -6
I'm done fixing something this piece of sh*t.
If I buy a new engine can I just take out the old oone and put in the new?
I have a gy6 50cc 139qmb shortcase engine.
Can I just buy the shortcase 150cc gy6 engine and swap it out or will I run into complications?
Post by Deleted on Jun 23, 2013 22:32:32 GMT -6
You can, but get a good carb too as most don't come with one. You may need an exhaust gasket or O ring too. Also make sure the exhaust will line up with the head and make sure your CDI and coil are good.
Installation is a snap, just remember to mark everything and take pics of everything as you go.
Engine swap
by: jjoshua20213 - Jun 23, 2013 23:52:36 GMT -6
Post by jjoshua20213 on Jun 23, 2013 23:52:36 GMT -6
Post by Alleyoop on Jun 24, 2013 0:10:29 GMT -6
You have to have the measurements of your mounts on the frame and width of the front mounts and the length of the rear mount. Or measure your current motor mounts and get a motor with the same distance mounts so it will slap in your current frame. Alleyoop
Post by Deleted on Jun 24, 2013 1:05:51 GMT -6
Want my honest opinion? Do the research, watch some vids and start tearing down the one you have. Why, you ask? Two reasons.... 1 You gain the knowledge! Most important! 2 You can get the best parts available and the tools for close to the same price as an El-cheapo replacement. Yea, it's the long way around but you will get an engine that will last with proper maintained. Before you say no, go out, grab a tool and dig in! What ya got to loose?
Engine swap
by: jjoshua20213 - Jun 24, 2013 1:05:56 GMT -6
Post by jjoshua20213 on Jun 24, 2013 1:05:56 GMT -6
Would all gy6 139 qmb short cases case the same size mounts?
