Post by epdowd on Oct 11, 2013 12:32:27 GMT -6
I have a problem that others may have had and can give some tips. To access the stator, I removed the crank case nut, removed washer, screwed the removal tool - left hand threaded - all the way in, secured Fly wheel with a strap wrench. When I screwed in the removal tool to remove the Fly Wheel the threads on the tool and maybe the Fly wheel stripped. I'm stuck !!. I contacted GY6 Racing team that I bought the tool from, waiting for a reply. Has any one had this problem.. Thanks,,, Harv..
Post by jct842 on Oct 11, 2013 12:50:25 GMT -6
Do a search here.....Don't remember who but some one here had the same problem in the last year.
Post by Alleyoop on Oct 11, 2013 12:53:11 GMT -6
Yea, its the wrong size puller is what it happened to be. Alleyoop
Post by epdowd on Oct 11, 2013 16:19:52 GMT -6
This puller is 27mm, should be correct for the 150cc, 139QMJ engine. I put the crank nut back on flush with the crank shaft threads, Used a hammer, a piece of hard wood and smacked the thing about a dozen good blows---- No luck there either,,, Bummer..l I guess I'll have to find another type puller, any tips on that ?.. Thanks..
Post by epdowd on Oct 11, 2013 18:28:18 GMT -6
Our Guru tvnachman just gave me some tips.. I'll let you know how they work after I get the tool, maybe help another member with this problem.. A big thumbs up for tvnachman !!!!!!!
Post by tvnacman on Oct 11, 2013 19:14:34 GMT -6
Post by epdowd on Oct 11, 2013 20:50:09 GMT -6
OK John,, got it....
Post by epdowd on Oct 31, 2013 7:44:13 GMT -6
It works fine.. I could only get two bolts lines up with the fan bolt holes, but I would have been stuck without it.. Great tip,, Thanks again !!!.
