Post by bobthetechguy on Oct 13, 2013 10:50:30 GMT -6
My 2010 taotao 50 peace motorsports is having electrical problems. Sometimes it won't crank. I'll press the button and nothing happens. If I turn the key off and back on a couple times it works fine. The guages light up and fuel level comes on just fine.
Also now my headlight doesn't work. At first the low beam side went out and I could just switch it to high beam and it would work. Now I have no headlight at all. The blue light in the guage cluster still lights up to indicate when high beam is activated if that makes any difference.
This really sucks as I dont have a kick start lever on my scooter(PO removed it for some reason)
Post by Deleted on Oct 13, 2013 10:55:23 GMT -6
about the headlight: have you changed the bulb? if it was the original bulb, it could have just been on its way out.
Post by tvnacman on Oct 13, 2013 10:56:29 GMT -6
check the " AC voltage at the head light " check the starter switch makes good ground . check to see if the brake light is lit when trying to start . power to the coil of the solenoid comes off the brake light ckt and ground comes from the starter switch . As far as the headlight bulb they could be defective , however if the AC voltage spikes it will burn them out .
Questions ?
Post by bobthetechguy on Oct 13, 2013 15:30:00 GMT -6
So just found out turning the ignition on and off doesn't help. But I have to fiddle with the starter button. I'm assuming its loose wiring after riding some bumpy roads yesterday. Will tear it down tomorrow and check.
As for the light is there anything brighter I can put in there that will fit without mods? The stock light is just too dim for these country roads..
Post by bobthetechguy on Oct 13, 2013 15:30:56 GMT -6
Yes brake light is lit when trying to start, as is the running lights , and blinkers if i activate them.
Post by tvnacman on Oct 13, 2013 16:18:04 GMT -6
Trace from the - battery to the frame , there should be a few wires under that point . Take that apart clean the underside for good electrical connection . Follow the other wires from the past point and see where they connect and clean the connections . I'm a big fan of adding good wire to aid the stock harness . Some will add a wire from - battery to the valve cover inserted under a bolt , then continue on to the area under the handle bars and splice to the green on the ignition switch . I also pull a heavy wire via a fuse from the battery + to the ignition switch red wire .
Post by bobthetechguy on Oct 14, 2013 11:29:41 GMT -6
What's the brightest headlight(better than stock) I can put in there?
Post by mikey34 on Oct 14, 2013 20:55:32 GMT -6
It depends on your Bulb Connection. If its a two point connection on the bulb, I have seen as high as 55watts, but thats it. I just bought a pair of 20 dollar fog lights from Advance Auto Parts, so I could direct them where I want. They're alot bigger and brighter and they make my scoot look like a Ruckus hahaha
Post by bobthetechguy on Oct 14, 2013 23:20:57 GMT -6
Ended up getting a stock replacement from local shop. It was cold, raining and getting dark early . someday I wanna get some super bright LEDS.
Post by tvnacman on Oct 15, 2013 3:30:50 GMT -6
cree
Post by Bashan on Oct 15, 2013 6:28:59 GMT -6
Geez John, I didn't know you had American Indian heritage. You're a trip buddy.
Post by tvnacman on Oct 15, 2013 7:21:56 GMT -6
I mention Cree led, nothing besides Cree led.
Post by bobthetechguy on Oct 15, 2013 13:17:19 GMT -6
I'm also native American Indian also.
Post by tvnacman on Oct 15, 2013 14:09:52 GMT -6
I'm also native American Indian also. I only see a person posting for help . Sex race color creed I don't see or makes any difference . Clean grammer and respect is what matters . I was unaware cree has anything to do with indian . Yes cree led's are the brightest . John
Post by Alleyoop on Oct 15, 2013 14:24:30 GMT -6
And here I thought you meant to type Great and missed a few key strokes (HAHA). Alleyoop
