regulator
by: Deleted - Feb 24, 2014 19:00:03 GMT -6
Post by Deleted on Feb 24, 2014 19:00:03 GMT -6
hey all i got a question. was looking over my sscoot and realized that my regulator isnt like any on the scrappydog site. its four wire but mounts differently. heres a pic the scooter is the lintex one in my sig.
regulator
by: Bashan - Feb 24, 2014 19:40:03 GMT -6
Post by Bashan on Feb 24, 2014 19:40:03 GMT -6
If the wire colors are red, green, white, and yellow its a standard GY6 R/R. The body of the R/R doesn't matter so much but the wire colors do. The body on that R/R looks to me like it grounds right to the frame. I bet if you checked continuity from the body to a ground you'd get continuity. I don't know why they do that and then have a ground wire also.
regulator
by: Deleted - Feb 24, 2014 19:45:14 GMT -6
via mobile
Post by Deleted on Feb 24, 2014 19:45:14 GMT -6
yup thats it. does it need to be grounded? on mu other scooter somebody ziptied it on instead of bolting it.
in that case i guess the little square one would work wouldnt it?
regulator
by: tvnacman - Feb 24, 2014 19:50:05 GMT -6
via mobile
Post by tvnacman on Feb 24, 2014 19:50:05 GMT -6
regulator
by: Deleted - Feb 24, 2014 20:28:05 GMT -6
via mobile
Post by Deleted on Feb 24, 2014 20:28:05 GMT -6
Yup. Price is kinda steep tho. Would a standard square one work?
regulator
by: tvnacman - Feb 24, 2014 20:33:16 GMT -6
via mobile
Post by tvnacman on Feb 24, 2014 20:33:16 GMT -6
I think its mis marked should be $20 . I have the small one too .
regulator
by: tvnacman - Feb 24, 2014 20:34:50 GMT -6
via mobile
Post by tvnacman on Feb 24, 2014 20:34:50 GMT -6
I would not out power to any regulator without being mounted .
regulator
by: Deleted - Feb 24, 2014 20:42:52 GMT -6
via mobile
Post by Deleted on Feb 24, 2014 20:42:52 GMT -6
Here's pics of my small square one and the other weird ones wires. Looks the same to me
regulator
by: Deleted - Feb 24, 2014 20:48:58 GMT -6
via mobile
Post by Deleted on Feb 24, 2014 20:48:58 GMT -6
ok just tested. the nomal square ones ground pin is grounded to the body of the reg. the weird one on my other ones pin is not grounded to the body of the reg but of course the terminal in the connector is grounded still. would the normal square one still work in its place? i would think so.
regulator
by: Deleted - Feb 24, 2014 21:40:47 GMT -6
via mobile
Post by Deleted on Feb 24, 2014 21:40:47 GMT -6
what do you guys think?
regulator
by: Deleted - Feb 24, 2014 22:39:55 GMT -6
via mobile
Post by Deleted on Feb 24, 2014 22:39:55 GMT -6
also the other four pin square connector one at scrappydog has a floating ground. would that be like the weird one on my scooter?
regulator
by: tvnacman - Feb 25, 2014 4:53:23 GMT -6
via mobile
Post by tvnacman on Feb 25, 2014 4:53:23 GMT -6
The one that grounds to the body of the regulator is different then the one that does not . The worst that will happen is you will smoke it .
what foes Scrappy say .
regulator
by: Deleted - Feb 25, 2014 9:37:37 GMT -6
via mobile
Post by Deleted on Feb 25, 2014 9:37:37 GMT -6
scrappy has one that has the same connection but looks different and has a floating ground. its still four wire and everything. is that the one id need?
regulator
by: Deleted - Feb 25, 2014 10:07:40 GMT -6
Post by Deleted on Feb 25, 2014 10:07:40 GMT -6
heres a couple much better pics describing it.
regulator
by: Deleted - Feb 25, 2014 10:55:10 GMT -6
Post by Deleted on Feb 25, 2014 10:55:10 GMT -6
heres the listing for the floating ground one. is this what I need?
