Post by mxmatt on Mar 7, 2014 0:00:21 GMT -6
Before I replaced my crank, I never had this problem but now a good percentage of the time my starter seems to not engage, partially engage, or make a gear grinding noise before catching and then starting my bike. What gives?
Post by FlyingBlindOnARocketCycle on Mar 7, 2014 8:15:38 GMT -6
It's possible that the end of the bendix that sits in the left side engine cover isn't in the hole it's supposed to be in, or the washer that should be on the bendix shaft on the engine side might have fallen away.
Post by twowheeler on Mar 7, 2014 8:19:04 GMT -6
What method did you use to remove the variator nut? I have seen some methods actually warp the drive fave and that will cause your problem!
Post by mxmatt on Mar 7, 2014 17:19:55 GMT -6
What method did you use to remove the variator nut? I have seen some methods actually warp the drive fave and that will cause your problem! Impact. Not that tight. Drive fave?
Post by mxmatt on Mar 7, 2014 17:20:54 GMT -6
It's possible that the end of the bendix that sits in the left side engine cover isn't in the hole it's supposed to be in, or the washer that should be on the bendix shaft on the engine side might have fallen away. Bendix?
Post by Deleted on Mar 7, 2014 18:57:36 GMT -6
It's possible that the end of the bendix that sits in the left side engine cover isn't in the hole it's supposed to be in, or the washer that should be on the bendix shaft on the engine side might have fallen away. Bendix? i believe he is talking about a 50cc. your 150 I dont think has one. it has a clutch instead
Post by mxmatt on Mar 25, 2014 14:02:47 GMT -6
I am still having this problem. What would cause my electric starter not to engage most of the time. When I hit the start button normally I get a screech and then sometimes it will engage and start my bike right quickly. The noise it makes sounds like gears grinding. Prior to changing my crank this never happened.
Post by Alleyoop on Mar 25, 2014 14:09:20 GMT -6
If its a 150cc motor it has a Starter Clutch inside the left cover behind the Stator. It is your starter clutch, you many not have tighten the nut enough or you put the washer on the wrong way. Alleyoop The gear above the big starter clutch gear is your Idler gear which the starter turns that in turn turns the starter clutch. Now the end of the shaft on the idler gear fits in a recess on the inside of the cover to keep it straight and level and in place.
Post by mxmatt on Mar 25, 2014 16:15:39 GMT -6
That totally makes sense alley. Since I'm leaking oil like crazy already, I'll just do a tare down and redue my gaskets. I need one of those special sockets to tighten the clutch bolt to specks. I guessed using a screwdriver and mallet! Doh!
Post by mxmatt on Mar 25, 2014 16:18:29 GMT -6
When I redue this, should the Variator be installed before the clutch bolt is torqued?
Post by Alleyoop on Mar 25, 2014 16:20:26 GMT -6
Don't forget an OIL SEAL is inside the cover so make sure you put in a new OIL SEAL that may be where it is leaking oil. But once you take the flywheel off you will know if the seal is leaking because you will see oil around the Crank Or it could be leaking around the cover plate. Alleyoop
Post by mxmatt on Mar 25, 2014 19:34:20 GMT -6
Do you have a pic of the oil seal?
Post by mxmatt on Mar 26, 2014 10:10:42 GMT -6
Alley, I'm not sure if you saw this question. We were posting at the same time.
Also,
Post by Alleyoop on Mar 26, 2014 17:38:39 GMT -6
You do not have to worry about tighten or torqueing the variator or clutch first they are independent of each other. So put on the belt and then tighten whichever one you want first does not make a difference. Here is a picture of where the Crank Oil seal inside of the stator plate. Alleyoop
Post by mxmatt on Apr 4, 2014 22:05:50 GMT -6
Alley, when I pulled the fan cover off, I did not see a bunch of oil in the stator housing area like I anticipated I would. I don't think it is the oil crank seal like I suspected. It seems like the oil is coming from somewhere else.
