Post by mxmatt on Mar 17, 2014 22:12:32 GMT -6
While changing the oil in my scooter today, I noticed that my rear wheel has some lateral play in it. It is very minor, but is this normal? Seems like it should only move forward and backward. It is torqued to specification.
Post by Deleted on Mar 17, 2014 22:24:34 GMT -6
if its torqued, then it shouldn't move. could be your drive axle/ shaft bearing. are you sure your whole engine isn't moving? could be shock mount bushing or front mounts
Post by tvnacman on Mar 18, 2014 9:40:46 GMT -6
if its torqued, then it shouldn't move. could be your drive axle/ shaft bearing. are you sure your whole engine isn't moving? could be shock mount bushing or front mounts 2nd this , sometimes if you look carefully you may be able to determine if it is the wheel bearing or the axle bearing . If the whole wheel and axle moves it is the axle bearing , if the axle does not move then it is the wheel bearing . I would retorque the wheel just to be sure it did not back out . We had the nut comming loose because of the wheel bearing being seized . John
Post by mxmatt on Mar 20, 2014 22:31:31 GMT -6
if its torqued, then it shouldn't move. could be your drive axle/ shaft bearing. are you sure your whole engine isn't moving? could be shock mount bushing or front mounts 2nd this , sometimes if you look carefully you may be able to determine if it is the wheel bearing or the axle bearing . If the whole wheel and axle moves it is the axle bearing , if the axle does not move then it is the wheel bearing . I would retorque the wheel just to be sure it did not back out . We had the nut comming loose because of the wheel bearing being seized . John Thanks John. When I torque'd it to 60lbs it fixed my issue.
Post by tvnacman on Mar 21, 2014 5:53:05 GMT -6
Great!!!! Keep an eye on it .
Post by tvnacman on Mar 21, 2014 6:16:30 GMT -6
Post by tvnacman on Mar 21, 2014 6:16:40 GMT -6
Post by Bashan on Mar 21, 2014 14:07:03 GMT -6
OK John!
Post by Bashan on Mar 21, 2014 14:07:15 GMT -6
OK John!
Post by Bashan on Mar 21, 2014 14:07:30 GMT -6
OK John!
Post by tvnacman on Mar 21, 2014 17:04:58 GMT -6
Rich stop breaking my balls , i'm trying to to bump my thread count . Mobile data problems .
