Post by mxmatt on Mar 25, 2014 19:50:23 GMT -6
A month back I opened my cvt case and a small spring fell out on the floor.
Post by Alleyoop on Mar 25, 2014 20:43:35 GMT -6
Post by Deleted on Mar 25, 2014 20:47:52 GMT -6
Alley, I think he was asking whether a little spring was in that indicated hole.
Post by Alleyoop on Mar 25, 2014 21:09:03 GMT -6
MXMATT, Is that the CVT COVER if so Take a picture of the whole cvt cover. I have never seen a small spring on the 150s other than the ones in the picture I put. And here is a video on how to align the gears. alleyoop
Post by mxmatt on Mar 25, 2014 21:31:09 GMT -6
Post by Alleyoop on Mar 25, 2014 22:22:32 GMT -6
Sorry I have no idea why that little hole is there where the big gear shaft fits in. The only thing I can think why a spring would be in there is to put pressure on the shaft to push it back into place because that gear should always be behind the Crank Starter Gear. So if its a small spring that fits in that little hole I would put it in.
The way it works is when you Kickstart that big gear moves out and engages the gear on the crank and it supposed to retract back. So maybe the spring always has pressure on the shaft to make sure the whole shaft is pushed back. Alleyoop
