Post by sumdawgtwigg on Apr 1, 2014 14:16:25 GMT -6
Went out to ride the scooter yesterday and it would barely start. Once it does start it bogs down very badly and puffs blue gray smoke. I adjusted the valves, put on a new carb, adjusted new carb, and it still does the same thing. There is a very bad pinging sound coming from the engine. Any ideas? like i said, I adjusted valves to proper setting, then put a new carb on and adjusted it.
*edit* this my my wildfire 150cc scooter.
Post by Bashan on Apr 1, 2014 15:48:19 GMT -6
Ow, pinging is not good, blue grey smoke is not good.
Survey: Are you good with a wrench? Ans:
Yes: check your compression, if it's below 110 you either broke a ring or a valve seal is trashed.
No: Check on Ebay for a complete engine.
Seriously, you combine those two findings you gave me and it is usually catastrophic. Blue smoke is burning oil and pinging is metal components hitting each other. Sorry.
Post by sumdawgtwigg on Apr 1, 2014 17:34:13 GMT -6
that's what i was afraid of, stinky. I just wanted to get a second opinion. I just really don't even want to deal with it anymore. I'm going to sell it and buy a 250cc or above motorcycle. I used to love these china scoots but this really puts a bad taste in my mouth. I only owned it for three months before this started happening.
Post by adamhoyer on Apr 1, 2014 19:57:39 GMT -6
I removed my spark plug while it was hot and put it back in and stripped it and it made a clicking pinging noise but no blue smoke.
Post by jvino on Apr 2, 2014 8:43:33 GMT -6
Sounds like the valves I would double check your work good luck.
Post by bobthetechguy on Apr 6, 2014 11:40:23 GMT -6
Are you running premium fuel?
Post by sumdawgtwigg on Apr 27, 2014 19:28:33 GMT -6
I checked and rechecked the vales so that's not it. i appreciate it though.
Yes, i am. Someone is coming to look at it tomorrow and hopefully buy it. Already eyeing a few motorcycles.
Post by adamhoyer on Apr 27, 2014 20:27:30 GMT -6
Last time I heard a pinging sound in a moped engine it was from running out of oil and some metal ball was floating around in the crank case. "in reference to the scooter engine".
Post by Deleted on Apr 27, 2014 22:44:29 GMT -6
Last time I heard a pinging sound in a moped engine was from running out of oil and some metal ball was floating around in the crank case. "in reference to the scooter engine". mustve been a ball from one of the bearings. nasty stuff.
