Post by adamhoyer on Apr 5, 2014 13:32:06 GMT -6
Hopefully I put enough oil on the cam and rocker arms and put the cam tension-er back on correctly. Well anyways I have a question about the positive negative thing. Which one of these is the positive left to right or right to left? 1drv.ms/1oBH5KA
Post by adamhoyer on Apr 5, 2014 16:13:09 GMT -6
Ok found out the correct wiring and got the engine running, no pops and its running smooth and a little boggy might have to adjust carb in a little bit.
Post by jvino on Apr 5, 2014 18:50:36 GMT -6
That's great good job I think I heard one of the more guys with experience say leave the plastics of for a little bit of running around to re torch the bolts on the engine.
Ride on adam hoyer great job keep us postided how it runs for you. You are probley right adjust the idle a little bit. Keep up the great work and hope it all works out well for you.
