Triangular Shaped Head!!
Post by FACE PLANT FOR LIFE on May 4, 2014 12:52:41 GMT -6
Post by Alleyoop on May 4, 2014 14:10:36 GMT -6
Best thing to do is take yours off and match it as well as the wires. There are so many of those they may have changed them from year to year. Alleyoop
Post by FACE PLANT FOR LIFE on May 4, 2014 14:13:37 GMT -6
Okay. I also just did a compression test on it. 120 PSI, not enough to run. This bike has more issues than I thought.
Post by jct842 on May 4, 2014 14:19:48 GMT -6
Most will run with 120 lbs but usually show symptoms. My majesty was still running with 85-90. But not well and blowing oil out the vent.
Post by jct842 on May 4, 2014 14:20:26 GMT -6
oops
Post by FACE PLANT FOR LIFE on May 20, 2014 15:54:31 GMT -6
Okay, so maybe it does have enough compression to run, but that still leaves us with intermittent spark. The spark just works when it wants to...you can sit there and crank the engine with the plug grounded to the engine all day but you'll be lucky if it sparks once or twice.
Okay, so it sparks...just rarely.
Post by Bashan on May 20, 2014 20:33:54 GMT -6
Did you blow oil out your vent again John? We talked about this.....
A of N....do you have a wiring diagram? Hyo's are odd ducks and I'd be guessing, but usually the yellow is AC to the headlight etc. It wouldn't have anything to do with the spark....on a regular GY6. The CDI power feed or the trigger could have something to do with it, but I'd have to look at a diagram. Maybe Jack has one....I'll ask him. Rich
Post by Bashan on May 21, 2014 7:33:03 GMT -6
Well Jack came through for us, here is your stator config:
As I suspected, it is a conventional system with different colored wires. This is a good illustration of the center tap. You can see the coil on the right (W/R) is analogous to the white wire on a GY6 stator. The other coil (Y/W) center taps into this coil and it is this one that is analogous to the yellow AC supply on a GY6. Those two wires do not have anything to do with spark. However, the white and brown are the trigger coil and the B/R is the AC power to the CDI. All three of those could be affecting the spark. Rich
Post by FACE PLANT FOR LIFE on May 21, 2014 15:43:20 GMT -6
Unfortunately, none of those wires match any wires on the CDI?
Post by Alleyoop on May 21, 2014 15:50:17 GMT -6
Well how about some help, take a picture of your CDI with the wires plugged in. Alleyoop
Post by FACE PLANT FOR LIFE on May 21, 2014 15:52:56 GMT -6
Post by Alleyoop on May 21, 2014 18:06:57 GMT -6
WOW!! that is the opposite of the CDIs that everyone sells. The two plug is on the left and the 4 plug is on the right. See what I mean PICTURES are worth a thousand words. That is the first one I have ever seen like that. Alleyoop
Post by Bashan on May 21, 2014 18:19:44 GMT -6
IF the colors are consistant with the GY6s, the white/blue is the trigger, the black/yellow the coil feed, and the black/red is AC CDI feed. The others? I'd be guessing because as Alley said, the plugs are totally unconventional. You would have to get the multi out and start some testing. I can tell you what to do if you wish to pursue it. Rich
Post by Alleyoop on May 21, 2014 18:53:30 GMT -6
Post by Bashan on May 21, 2014 22:09:57 GMT -6
Hey Plant....is that a 2T? It looks like it in the link Alley provided. Rich
