Post by streetglide on Sept 3, 2014 15:25:30 GMT -6
It was runing fine then went to start,wouldn't run ,checked for gas,none,pull vac line off and used hand vacume to open valve ,thus allowing gas to Flo to carb
Post by streetglide on Sept 3, 2014 10:40:17 GMT -6
What I'm saying is why does motor Run with a vacuum leak?
Post by streetglide on Sept 3, 2014 5:53:49 GMT -6
Would not run unless you applied manual vacuum to fuel valve so it could get gas. Then when you get it running & hook vac back to vac port it would die. Fuel valve works fine.
Post by streetglide on Sept 2, 2014 20:12:16 GMT -6
Why when I block off vac port(at intake) with finger it dies, it should run better,that's the same when I hook hose to it. No gas in vac hose. Valve works fine (opens &close) also when you turn engine over air blows out vac port at intake then it will start vacuuming??? Valve problem?
Post by streetglide on Sept 2, 2014 20:05:08 GMT -6
Post by streetglide on Sept 2, 2014 20:01:57 GMT -6
Why when I block off vac port(at intake) with finger it dies, it should run better,that's the same when I hook hose to it. No gas in hose. Valve works fine.
Post by streetglide on Sept 2, 2014 15:50:03 GMT -6
Thanks for the ideas. It will run with vac line off ,until it drains carb bowl
Post by streetglide on Sept 2, 2014 4:30:01 GMT -6
Why does the motor die,when vacuum,from fuel tank valve is connected to intake manifold port? Runs great with port open,but if you block it with finger it will start to die. ( when it should run better) Thanks
