Post by ahmed on Oct 22, 2014 17:56:40 GMT -6
Thank you alleyoop for helping NOW I installed 2 battery after full charge and put the second battery in the scooter box under seat and connect it with other battery as parrell connection and everything is ok now I appreciate your help and support to get it work
Post by ahmed on Oct 18, 2014 16:19:01 GMT -6
Today i charged the battery with battery charger and mesure it after installing it in my scooter DC was 13.20 v Start scooter at idle speed drained to 12.75v Give it some rpm raised to 13.50v My scooter is sym fiddle 2 125 cc What should i do ? Thanks for helping me
Post by ahmed on Oct 17, 2014 20:40:02 GMT -6
Thanks alleyoop now it's 4:35 am so i will test it afternoon and post the results thanks again
Post by ahmed on Oct 17, 2014 19:48:41 GMT -6
Thanks alley for reply i do this tests with the hid turned off not on with the wire connected to battery
Post by ahmed on Oct 17, 2014 19:23:02 GMT -6
First hello to all my name is ahmed and iam from egypt iam working in electronics and i have some experince on this field i was modified my scooter light system by swipe front turning signals into a white led lights and connect the led with a small lamp on the headlight torch second install hid xenon with ballast by arelay part with direct wires from battery since i installed it my stock battery got bad and it cannot start my scooter i bought a new one then installed it and every thing work fine for about one month now it seem to be a charging problem the scooter starts hardly then now it cannot start i kicked it and go for my work about 1 hour riding it at 80 km/h when i arrived my work let it for about 5 hours and trying to start it again it cannot start i checked the rec/reg mesure by voltmeter between green wire as ground and both white and yellow wire on AC i got 10-15 volt then i mesure the output of reg/rec without battery installed on the scooter was 6.5 at high rpm then i unpleged stator socket and do mesurment betwen green as a ground wire and both white an yellow wires was about 30 v on yellow and 35 v on white then i bought a new reg/rec install it do mesure output was 6.5 at high rpm finally i tried to charge the battery in my workshop with battery charger on 2A current for 1 hour and install battery again on my scooter and everything work fine for 3 days then it draind and cannot start my scooter is it possible that the new reg/rec was bad? or its a stator problem?
please help me solve this problem thank you
