Post by akuma on Nov 8, 2014 19:29:37 GMT -6
Great thanks. I will try that tomorrow. Will post update.
Post by akuma on Nov 8, 2014 19:03:19 GMT -6
Hello, Would like to know if anyone knows why my positive cable is turning black. After a while of riding it starts smelling like rotten eggs mixed with battery acid from the battery compartment and now my battery is no good. Just bought a new battery but don't want to connect until I know what's going on so it doesn't burn out the new one as well. Also have a 30 amp fuse on it just in case it help troubleshooting the problem. i1372.photobucket.com/albums/ag352/Akuma55/battery_zps12221047.jpg
Post by akuma on Oct 25, 2014 16:41:55 GMT -6
Thank you buddy I appreciate the help.
Post by akuma on Oct 25, 2014 15:43:19 GMT -6
Here is the update. Red shows the fuel filters added to the end. Green shows the straight hose "t" removed and blue the fuel line straight to carb. I think I have to much slack on the fuel hose and should probably cut it shorter so its a nice smooth short curve going down. Let me know if everything is ok. i1372.photobucket.com/albums/ag352/Akuma55/Step6_zps9c3929a2.jpg
Post by akuma on Oct 22, 2014 21:08:33 GMT -6
Ok will do. Will post updated pictures tomorrow to make sure everything is correct.
Post by akuma on Oct 22, 2014 19:25:20 GMT -6
Great I will buy the filters and try that tomorrow.
Post by akuma on Oct 22, 2014 18:21:38 GMT -6
Great I will do that. Thank you ally. What of the remaining hose coming from the fuel tank?
Post by akuma on Oct 22, 2014 18:00:58 GMT -6
On pic 4 I have a hose coming from the top of the fuel tank and follows on pic 5 and I just left it hanging outside as I don't know what to do with it.
Post by akuma on Oct 22, 2014 17:57:37 GMT -6
Is pic 3 ok? Should i run a straight hose and remove the " T " since I no longer have a petcock as I removed it and put a manual fuel cutoff.
Post by akuma on Oct 22, 2014 17:55:23 GMT -6
[/URL] Here's what I'm left with in pic 1 and continues on pic 2.
Post by akuma on Oct 22, 2014 11:59:10 GMT -6
Hello to all.
Need help with removing the EGR (Pair System) from my 150cc gy6 scooter. Actually it's already removed and pcv block off plate installed but but no one shows the complete procedure of what to do with the remaining hoses after you remove the factory air box and canisters so that everything runs perfectly. Any help will be greatly appreciated and hope this will help others as well that want to remove it and just run with an aftermarket air filter. I will post the pictures of what I have left and hopefully you guys can guide me step by step on what to remove and what to leave.
Thanks in advance.
Regards,
Akuma
