Post by unclemike71 on Feb 26, 2015 13:29:12 GMT -6
If the oil level doesn't go down it isn't working but in mean time premix or you will kill the engine. Thanks for that .....what ratio on these things?
Post by unclemike71 on Feb 25, 2015 0:45:49 GMT -6
Bad or plugged oil injector? If it sat a while the injector may have gotten plugged or gummed up,,, Does it have oil in it?,,,sorry I had to ask,,was it a " soft" seize? I hope so ,, run the gas premixed Definitely sat, 300 original miles , oil in the reservoir....and yep soft seize.
Post by unclemike71 on Feb 24, 2015 22:44:52 GMT -6
I just got a Yamahopper with 300 miles on it, the guy I got it from couldn't keep it running. I brought it home ,cleaned the carb and it ran like a champ around the block. My son took it for a spin and seized. I cant tell if the oil injector is working or not. Any ideas of what could be the problem? Should I get a block off plate? HELP!!
