Post by dalusiot on Jun 28, 2015 5:30:22 GMT -6
I replaced the solenoid, with alleyoops help walking me through the different tests to determine that it was bad, from a picture of the cdi pin out he determined that it is a DC system and I have 12 volts going to the cdi , when I check the pickup coil on the top left of the 4 plug of the cdi connector I don't get a reading if I hold the start button down turning the motor over, if I just hit the button quick it makes the meter jump, I put a new DC cdi in as well as an ignition coil, the coil isn't different in a DC system, is it? I still have no spark, I guess I am going to order a stater put that in if it still has no spark I will let someone else fix it, I have more patience with things normally but I want to hear it run soon, It is in New condition, except new bikes start!!!! I'm still hanging in there
Post by dalusiot on Jun 26, 2015 15:24:33 GMT -6
Good to hear that you have it running!!!!
